07-31-2014, 04:16 PM | #1 |
| Rebuilding Former Glory SCX10 Axles...help!
Well my buddy has been running his Wraith with a powerful Tekin 3500HD motor/MMP setup on 2s with of course the necessary tranny gears, tranny case, tranny output shafts, MIP drive shafts, hardened bevel gear sets front and rear. I am doing the same but with SCX10 axles instead and on 1.9s not 2.2s. I also put on the new 8* chubs and knuckles with VP's titanium tie rod and drag for them. The rest of the rig is all VP titanium linkage as usual. I don't want to throw on Curries for the simple fact that they are just too expensive to throw em around. This rig is a low slung desert buggy meant for speed and jumps not really crawling. I may unlock the front diff with an open gear set or go IFS. But yeah so here's what I got low budget build up for durable strength: -6 year old Axial SCX10 housings!!!! Cleaned them up looking vintage. -New VP VVD's for SCX10 for that sick 50*!! -Replaced ALL NEW bearings or hardware that was looking they would round out -Reconditioned perfect shape OD front bevel gears -Greased new stock ratio HD bevel gears for the rear axle -Reconditoned STRC Rear lock out SS axle kit (also about 4 years old from my old shafty rig) -Checked both HR SHD locker gears and screws all look good and reconditioned them as well -VP 8* knuckles/c hubs installed along with new VP tie rod/drag link -Just ordered extended BeefToobz to reinforce and add lower weight -Cleaned my MIP drive line set and applied a dry lubricant afterwards -Front axle has temporary plastic 4 link from the new Axial kits -Rear is running a polished DMG 4 link...front will match as well once I get geometry done. Grease of choice: Team Associated High Temp Black Grease for diff rings Cleaner of choice: M Pro-7 Firearm Cleaner (safe on plastics, wood, steel, aluminum....) Bearings: All from Team Fast Eddie as usual Bearing lube of choice if I had to: Bones Speed Cream SO with that being said anything else I can do to these axles besides new housings? I see no point in ordering new plastic housing if mine are just fine. IF I were to upgrade housings then I'd go all the way with Curries. But let's see how long these babies last first! The build thread is here: page 2 is axle related. The Orange Crush Ultra4 EB Build!! Thanks!! |
Rebuilding Former Glory SCX10 Axles...help! - Similar Threads | ||||
Guts - Glory - Rata's Ram | Rataplan | Scale Videos! | 0 | 08-14-2012 03:21 AM |
Dust to glory | crash | Chit Chat | 4 | 12-03-2010 06:18 PM |
A liquid poem to the glory of the hop! | caci623 | Paint and Body | 26 | 05-09-2009 08:47 PM |
Attempt at scale glory. | xjman | 2.2 Scale Rigs | 14 | 03-01-2007 02:57 PM |
