07-31-2014, 05:48 PM | #1 |
Quarry Creeper Join Date: Jan 2013 Location: Long Island, NY
| JK kit shock help
Hey guys. I was looking at my truck sitting on the table before and I noticed then when I put it down onto the table, the front and rear sags a little bit. I have the adjuster nut all the way up on all shocks? Do I want to adjust that to add some preload, which will stiffen it up a little? Or do I want that little bit of sag? Also, what position on the shock hook should I run the shocks? |
08-01-2014, 11:47 AM | #2 |
In the band for now. Join Date: Sep 2012 Location: roselle
| Re: JK kit shock help
you can adjust the pre load on the shocks to get rid of the sag wont hurt it at all. its just the weight of the rig that makes it sag.
08-01-2014, 12:06 PM | #3 |
the static ride height should not be at it's most upper pre-load limits. Look at a 1:1 rig even stock... and you will see that it is nearer 60/40 (down/up travel) I roll my chassis at a static ride height that is nearer 50/50 in it's wheel travel. Some folk pre-load excessively so that they may fit taller tires. But that is not the correct way... unless yer building a pogo stick. The proper way would be to trim the body as necessary if rolling tires the size of which is more appropriate to that of a Caterpillar. |
08-02-2014, 07:39 AM | #4 |
RCC Addict Join Date: Nov 2008 Location: Bunnell, Fl.
I leave the rear alone, sometimes I will adjust the front a little bit, but I dont do it via the preload nut. What I do is put a longer shock eye on the bottom. By doing that it raises my ride height slightly to compensate for a heavy font end (steel bumper, winch, battery pack) without changing the preload.
08-02-2014, 09:48 PM | #5 |
Pebble Pounder Join Date: Feb 2014 Location: Tracy
I run mine a lil farther down then they come on RTR...a lil over halfway...work great...on my Honcho with steel bumpers and a stereo system(lol) Sent from a whiskey downer beer pounder's shop |
JK kit shock help - Similar Threads | ||||
RPP Shock Relocation Kit | HDMM | Axial SCX-10 | 5 | 07-16-2012 09:54 AM |
New Kit, greases, shock oils, etc? | Beej | Axial Wraith | 2 | 11-28-2011 08:31 PM |
losi shock rebuild kit........... | bob1961 | General Crawlers | 2 | 04-27-2009 10:24 PM |
Kit shock length? | genki | Tamiya CR-01 | 4 | 04-27-2008 05:44 PM |
