Ford F-250/350 Body I have searched and searched the forum for ford bodies that would for my new deadbolt. Any help will be greatly appreciated. Also if I wanted to would the honcho F-250 body work? Thanks |
Re: Ford F-250/350 Body Personally I like the pro-line#3252-00 2008 F250 crew cab body, it has a 12.8" wheelbase so you will have to use longer links to adjust your wheelbase. It will work though and look very nice. Pro-Line 2008 Ford F-250 Body 3252 for Monster Truck The Pro-Line F250 body for the honcho will fit if you get a Honcho back half cage, but again, you might have to adjust your wheelbase, just not as much. The Honcho wheelbase is 12.3" Pro-Line Ford F-250 Super Duty Cab 3392 for Rock Crawler The Deabolt wheelbase is the same a the Recon G6 and is 12" |
Re: Ford F-250/350 Body Like stated above if you want to use the f250 cab you will need the honcho rear cage section, that doesnt let you keep any electronics or batteries in the rear section of the frame. |
Re: Ford F-250/350 Body Already planned on moving battery and electronics so thanks for the input thumbs up. |
