08-07-2014, 10:07 AM | #1 |
Newbie Join Date: Dec 2010 Location: Nova Scotia
| motor squealing
Scx 10 honcho all stock. After some hard use I tore all the axles apart and found a few seized bearings from sand so I cleaned it all up and fixed it and everything seemed good to go. Haven't ran it since but the other day a push it aside to do something and it squeaked at me so I rolled it forward and backwards and sure enough it was coming from the motor hardly there going backwards but pretty noticeable forward. Anything I can do to clean and/or lubricate the guts in the stock motor?
08-07-2014, 10:30 AM | #2 |
Pebble Pounder Join Date: Apr 2012 Location: springfield
| Re: motor squealing
Pop the motor off and submerge it in water. Run the motor for a while, this will help clean out any leftover gunk. Then I use a drop or two of chain saw oil on the bushing. That should help.
08-09-2014, 08:31 PM | #3 |
Pebble Pounder Join Date: Jul 2014 Location: Atlanta
| Re: motor squealing
Run it in water and/or spray electric motor cleaner in it then oil it and it should fix it. Sounds like it just needs a little cleaning out!
motor squealing - Similar Threads | ||||
Motor brushes squealing holmes torque master | kurtus | Electronics | 0 | 04-07-2010 11:48 AM |
