08-09-2014, 01:58 PM | #1 |
Newbie Join Date: Jun 2014 Location: USA
| driveshafts issue after 4 links upgrade
Hi Today I have upgraded my scx10 honcho to custom 4 links (front & rear) After I did the upgrade, I noticed issues in the throttle performance, I do suspect it is from the driveshafts, the behavior is as shown in the below video Scx10 drive shaft issue? - YouTube Appreciate your support |
08-09-2014, 02:15 PM | #2 |
Rock Stacker Join Date: Jul 2014 Location: Hillsboro
| Re: driveshafts issue after 4 links upgrade
Did you line up the drive shaft? The cross member thing you have use on the front axle screwed down? I forget to screw mine down and had front axle shudders.
08-09-2014, 02:26 PM | #3 |
Newbie Join Date: Jun 2013 Location: two harbors
I bet your driveshafts are at too much of an angle. If you compress the springs and axles toward the truck does it stop? If so you'll have to clock your axles a bit to account for that.
08-09-2014, 02:27 PM | #4 |
I had to do the same thing with me scx10 after I added longer shocks, but any suspension change could do the same thing.
08-09-2014, 04:44 PM | #5 |
my bet is the the drive shafts were not reassembled correctly and are needing to be phased (aligned) there should be index marks > | < visible at both ends of the DS or simply align the pins of the universal joints |
08-09-2014, 04:51 PM | #6 |
Compress the suspension on the front axle and try it again.
08-12-2014, 01:10 AM | #7 |
Thanks guys, It was the angle, I lengthen the upper links and the chatter disappeared. I returned to 3 links in the front since I have the servo mounted to the chassis (rc4wd kit) and the links hit the 4 links truss on the axle. Now I am having another issue, the servo is turning one way fully, and barely turns the other way. I zeroed the servo, however, still the same, I feel that the front axles moves against the servo when it ttries to steer that direction. Appreciate your feedback |
08-12-2014, 01:21 AM | #8 |
Sounds like you didnt install the panhard link....
08-12-2014, 01:54 AM | #9 |
| Re: driveshafts issue after 4 links upgrade Thanks for the feedback, I bought this car used. Originally it didn't came with panhard link, and was working correctly The Kit I use is similar to the one in the below link http://www.rccrawler.com/forum/rc4wd...rvo-mount.html Last edited by questionare; 08-12-2014 at 02:16 AM. |
08-12-2014, 03:13 AM | #10 |
Not familiar with that one. The one i bought came with the panhard link in the kit..it was also from rc4wd.... |
08-12-2014, 05:29 AM | #11 |
Thanks, appreciate if others can help
08-13-2014, 12:55 AM | #12 |
I have a question, Do the drag link should be parallel to the link connecting the two wheels? At what angle should be the drag link? I feel it is on a high angle in my current setup which may caused the issue, and one note, if I left the truck of the ground, the steering works great at both sides, the issue is on the truck is on the ground Thanks again, |
08-13-2014, 05:08 AM | #13 |
Just an update, inhale solved the issue, it was the front axle angle,I clocked it and the steering worked correctly Thanks |
driveshafts issue after 4 links upgrade - Similar Threads | ||||
Steering Links Upgrade | hueyfisher | Axial AX10 2nd-gen | 10 | 02-06-2013 06:04 PM |
ckrc upgrade driveshafts/ yokes | Jgraser1 | Axial AX-10 Scorpion | 12 | 07-16-2012 05:53 AM |
MIP SplineDrive Shafts???? Upgrade driveshafts | AsILayDying | Axial SCX-10 | 13 | 07-23-2011 07:00 AM |
