08-17-2014, 12:16 AM | #1 |
Rock Stacker Join Date: Jan 2014 Location: Eagle Rock
| question about centering axles
guys how do yall get yalls wraith axles centered under the scx10 chassis? for some reason i cannot get them centered. i have the wraith skid plate. can anyone give me som tips? |
08-17-2014, 12:49 AM | #2 |
Rock Crawler Join Date: Jul 2009 Location: Victoria Australia
| Re: question about centering axles
What are you having problems with exactly, some pics might help but if your using the stock link mounts and your links are even length side to side you should be good.
08-17-2014, 01:55 AM | #3 |
Newbie Join Date: Jul 2014 Location: callahan
You can hook up 3 of the links and not the 4th? You may need to use different length links. |
08-17-2014, 03:16 AM | #4 |
ill get pics tomorrow
08-17-2014, 08:32 PM | #5 |
| Re: question about centering axles |
08-17-2014, 09:48 PM | #6 |
RCC Addict Join Date: Jul 2011 Location: Orlando
Looks like your upper link on the left (in the picture ) is longer than the right. Try unbolt in it from the chassis by the trans and see if that would alow it to center. Or its that the right is longer pulling it over to the right side. I would remove one at a time and see what happens. |
08-17-2014, 10:08 PM | #7 |
I would agree that the upper links dont match. Didn't mix up a link with the tie rod by any chance? |
08-18-2014, 04:36 AM | #8 |
if i do what yall said above then the other side goes out of wack
08-18-2014, 05:38 AM | #9 |
Looks like the chassis is too wide, what happens if you take the shocks off. Can you shorten the crossmembers and pinch the front in.
08-18-2014, 10:10 AM | #10 |
RCC Addict Join Date: Feb 2008 Location: Tekin, ID
I don't think you want to run a Wraith skid, it makes the chassis too wide and the shocks are pinched. Try it with an SCX skid and cross members.
08-18-2014, 02:46 PM | #11 |
Quarry Creeper Join Date: Jun 2006 Location: L-Town
As Ty said use the scx skid and braces, I 3 linked the front and rear of mine. I did u build thread of how I did it. Just mirror ur trans and either bend the 1 upper link or 3 link and panhard it
08-18-2014, 05:52 PM | #12 |
Nothing wrong with using the wraith skid, you just need to narrow the front and rear of the chassis for shock and turning clearance. |
question about centering axles - Similar Threads | ||||
centering pins for yota axles? | twilight | General Scale Talk | 7 | 03-23-2014 09:53 PM |
Servo Centering | baddley | Axial Wraith | 10 | 12-16-2012 10:15 AM |
dual centering dx-6 | joesbruiser | Electronics | 8 | 04-15-2007 01:44 AM |
self centering potentiometer | powertuned | Electronics | 0 | 05-13-2005 03:37 PM |
