08-19-2014, 10:05 PM | #1 |
Newbie Join Date: Nov 2012 Location: Australia
| First mods
Hey guys, i have a scx10 jeep wrangler limited rubicon, it's ,y first scaler. I have had it for a couple of months and think its time for some upgrades. What would you guys recommend as my first couple of upgrades. Also what wheels and tyres would you rate best as a all rounder.
08-19-2014, 11:13 PM | #2 |
Quarry Creeper Join Date: Aug 2014 Location: Mission viejo
| Re: First mods
Only real upgrade I'd recommend is aluminum steering link kit. On a lighter kit such as a deadbolt I haven't found it necessary but with the rubicon it's a must. I'm assuming you have the rtr here.... Tires in itself will be one of your best upgrades, only buy tires if you're willing to fork out the extra cash for nice foams... Pit bull rock beasts are hands down the most proven and award winning, you can't go wrong with them.. If you want to switch it up proline tsl xl and the new pitbull growlers look very good as well
08-20-2014, 09:00 AM | #3 |
RCC Addict Join Date: Nov 2008 Location: Bunnell, Fl.
| Re: First mods
Very 1st upgrade = Aluminum Steering Links 4-link the front (parts come with it) Move battery to the front (parts come with it) Then atleast lower aluminum links at some point as the plastic ones will start to bend and tweak when you get into some situations As far as tires, I also recommend the Pitbull Rock Beasts I like the Pro-Line Super Swamper TSL's alot, but the foams that come with them aren't so great so you would have to change them out for some CI ones. |
08-20-2014, 11:02 AM | #4 |
RCC Addict Join Date: Mar 2013 Location: Oklahoma City
| Re: First mods
For the price, you CAN NOT go wrong with the Axial Ripsaw R35 tires....Harder foams but those tires can be purchased for next to nothing as no one thinks they are worthy (tall enough). BUT, I run them on my G6 and absolutely enjoy the way they perform. If you want a taller tire, they Treppador tires have great traction all around. In my opinion, the Pitbull tires are simply too big (tall and wide) for any thing other than trail driving. Tires are up to you, whatever you think looks good just make sure you get a softer compound than those stock rock hard RTR tires. (SSX2, X3, G8, R35 compounds are proven) I use Axial Beadlock wheels with 3 screws on each side....never lose a bead, never twist a tire and I rock crawl with my G6. (Team brood 25T motor, 2 and 3s, overdrive front gears, Ripsaw tires with 3oz in each front wheel.) |
08-20-2014, 12:01 PM | #5 |
RCC Addict Join Date: Feb 2008 Location: Tekin, ID
| Re: First mods
I'd go in this order: 4-link the front (unless you plan to go chassis mounted servo steering) Move battery to front (better weight bias) Aluminum drag link and tie rod (stiffen up steering) Knuckles, C-hubs and universals (more steering throw) Wheels/Tires/CI Foams (up to you really) Steering Servo (more steering torque, especially if you go up in tire size) EX BEC (might be necessary if your new servo causes any brown-out issues with your ESC/Receiver.) Aluminum suspension links The list goes on for days, but that's just some ideas to get you started. |
08-20-2014, 12:21 PM | #6 |
| Re: First mods
aluminum suspension links (rear lower at least) should be MUCH higher on the list...they fold too easy. How do you plan to drive this vehicle anyway? What terrain, trails, rock crawling, high speed? What are your plans with it? |
08-20-2014, 12:32 PM | #7 | |
Newbie Join Date: Aug 2014 Location: Henderson
| Re: First mods Quote:
Where do you get harder foams for the stock tires? I have some trep's i want to try but the stock foams are way too soft. | |
08-20-2014, 12:42 PM | #8 | |
Crawler Innovations | |
08-20-2014, 12:45 PM | #9 |
| Re: First mods
They have 5 different kinds. Which one fits the narrow stock tires? While we are at it which are the ones that are supposed to be good for my 1.9 rockbeasts? thanks
08-20-2014, 12:55 PM | #10 |
| Re: First mods I run the Lil' Nova 2-stage 450's in my Rock Beasts, love them. Not sure for the Trepadors, I only run the 2-stage as the closed cell are too stiff for my liking.
08-20-2014, 05:30 PM | #11 |
| Re: First mods
thanks for the advise guys. mainly running on trails so dirt, sand, mud and abit of rock crawling. |
08-21-2014, 02:04 PM | #12 | |
Rock Crawler Join Date: Jan 2014 Location: Granite Falls, WA
I took my truck on a long, rocky, mountain hike yesterday, and had to be careful about the angles it got into. I'm not taking it on another serious hike, until I replace the foams. Not worth the risk of losing it down a steep slope. | |
08-21-2014, 04:38 PM | #13 | |
08-21-2014, 05:43 PM | #14 |
Newbie Join Date: May 2014
| Re: First mods
The chassis mounted servo set ups are more of an appearance upgrade in the scale realm as opposed to performance. Plus most aren't real cut and dry you need to be prepared for some major tinkering and getting new drag link set up. It would not be my first mod. My first mods were vanquish links getting the rig weighted 60/40 is the best mod just move battery in front of the tranny horizontal across the chassis using the extra servo mounts and the battery plate any questions feel free to ask I have currently a lot of mods on mine and they were all worth it barely ever break tons of speed and torque thanks to the tekin rx8 and a pro 4
08-21-2014, 05:56 PM | #15 | |
First mods - Similar Threads | ||||
must do mods? | TOYUTAH | Tamiya XC/CC01 | 9 | 04-13-2012 06:47 AM |
mods | axial11 | Axial AX-10 Scorpion | 19 | 08-06-2010 07:30 AM |
x-mods | Bronco | Chit Chat | 10 | 01-03-2007 04:26 PM |
new mods | motox | Tamiya Clod Buster | 3 | 12-31-2006 11:53 AM |
