08-28-2014, 06:27 AM | #1 |
Quarry Creeper Join Date: May 2013 Location: Knoxville
| Deadbolt vs Falken G6
I am about to purchase a rtr truck. What can't decide is if I should go with the deadbolt or the Falken g6. They are basically the same except the Falken comes with the Falken tires which people seem to like. It also comes with dual rate shocks instead of the single rate shocks on the deadbolt. It also comes with a jeep body which is better looking than the deadbolt imo. I like the deadbolt body but not as much as the Falken. Do you guys think those things are worth $50?
08-28-2014, 07:35 AM | #2 |
RCC Addict Join Date: Jul 2009 Location: Blacksburg, VA
| Re: Deadbolt vs Falken G6
There are a few other differences also. The chassis is different...with the G6 having the SCX10 chassis. The Deadbolt has a different axle design, as well, among other things. I think it all comes down to what you like and whether it's worth it to you to spend the extra cash. Personally, I like the G6 better. I don't care for the chassis design of the Deadbolt.
08-28-2014, 07:39 AM | #3 |
Quarry Creeper Join Date: Feb 2011 Location: Nevada
They are identical minus the tire tread and the body.
08-28-2014, 07:45 AM | #4 |
The shocks are different it says so on the axial website. I'm talking about the Scx10 deadbolt and Scx10 Falken g6.
08-28-2014, 02:22 PM | #5 |
You like the Falken body more, so your decision is already made. Underneath the body they are 100% identical. Except for the tires of course. Both the Trepadors and Falkens are both useless though, due to being glued on and having foam too soft to work properly after a couple runs. It's funny you mention the single springs on the Deadbolt... I have no idea why Axial did this, it's the only occasion on the entire scx line where they did this... I am happy about it though! They are working out great for me. They seem to be perfect stiffness right out of the box and as an added bonus they don't bind at all on the shock body like the stupid little collar that holds the 2 springs together does on all the other shocks. Last edited by Jus; 08-28-2014 at 02:26 PM. |
08-28-2014, 03:00 PM | #6 | |
| Re: Deadbolt vs Falken G6 Quote:
I think I will actually end up going with the deadbolt. The Deadbolt body is decent enough and $50 goes a long way towards a few upgrades. | |
08-28-2014, 03:02 PM | #7 |
You just might learn to love that Deadbolt body. I liked it from the first time I saw a pic... Seeing one in person is even better. The paint is very well done. Even has metallic in it. Looks awesome out in the sun.
08-29-2014, 02:07 PM | #8 |
Rock Crawler Join Date: Jan 2014 Location: Granite Falls, WA
I had the same decision to make, and ended up with the Deadbolt, because I couldn't justify the extra $50, even though I liked the color combo on the Falken G6. Plus, I already have a Rubicon clear body, from an unused JK kit, that I'll be using, once I get it painted. I'll probably switch back n' forth, depending on what I'm in the mood to look at. Hahaa.. The Deadbolt is pretty nice, and as others have said, sports a nice paint job. If you really detest the paint job, you could strip it and repaint it. I thought about doing that, myself, but it has grown on me. |
08-29-2014, 04:04 PM | #9 |
Quarry Creeper Join Date: Oct 2013 Location: Utah
Just get the Falken G6 body later on as a replacement shell.
08-29-2014, 04:19 PM | #10 |
Newbie Join Date: Aug 2014 Location: Pike County, Ky
I have both and you cant go wrong with either one.
08-29-2014, 06:20 PM | #11 | |
Quarry Creeper Join Date: Aug 2014 Location: Chilliwack
I have the Falken g6. I love the tires but the foams are too soft. I'm thinking of buying some axial beadlocks and another set of Falken tires but where would I find good foams? | |
08-29-2014, 10:50 PM | #12 |
Quarry Creeper Join Date: Aug 2014 Location: Mission viejo
Falken owner here. Yeah spent a couple bucks more but at the end of the day you're the one that has to look at the truck out on the trail so that's on you. For me, coming from a wrangler rubicon, I wanted a licensed body. Realistically you could sell the deadbolt body for $50+ on eBay, and buy a falken body for 60 or so, so saving $40 but then you don't get the tires. Your money man but you can't take it with you when you die
08-30-2014, 10:45 AM | #13 |
Rock Crawler Join Date: Feb 2011 Location: s. terra firma
If you were to sell the body from either the scx10 , the g6 jeep or the scx10 deadbolt keep in mind that the Roll Cage IS interchangeable on either body.
08-31-2014, 01:14 PM | #14 | |
Rock Crawler Join Date: Mar 2008 Location: 920 Valley of the Fox
08-31-2014, 04:28 PM | #15 | |
Quarry Creeper Join Date: Jan 2013 Location: Columbia
Crawler Foams | |
08-31-2014, 05:10 PM | #16 |
Quarry Creeper Join Date: Jun 2007 Location: east michigan
The AX-10 Deadbolt uses different chassis, shocks, and axles. Altogether its a different vehicle. The SCX-10 Deadbolt uses all the same stuff as the other SCX-10 vehicle line-up with a couple of exceptions. Chassis, axles, trans are all the same. Axial has made some minor changes/upgrades like going from 48 Pitch spur and pinion to 32 pitch pinion and spur, as well as the new Wildboar HD driveshafts and new speed control and servo. Dont forget about the shocks.....the ICON shocks are smooooth!!!! My personal opinion is they downgraded from the AE-2 to this new speedo, only because you could adjust the AE-2 with castle link. The new tactic servo was a good choice, but it could have been waterproofed like the speedo. Anyways the either truck you get you will have a blast with. Me personally, the green deadbolt is the way to go! I actuall converted my Honcho to the Deadbolt. The way to do that is shorter rear links and driveshaft and have the move the chassis shock mounts up 1 hole on the chassis then slap a deadbolt body on and call it a day. DONE.
05-01-2015, 11:20 AM | #17 |
Newbie Join Date: Apr 2015 Location: Upstate NY
Thanks for all the info. I'm trying to make the same decision deadbolt or g6 but what's everyone's opinion on the dual rate spring setup vs the single spring setup?
05-01-2015, 01:55 PM | #18 | |
Quarry Creeper Join Date: Feb 2015 Location: Amongst the UTards
You will likely upgrade the shocks in the future anyway regardless. They all leak. Get the deadbolt, save money, buy new shocks with it. No issues with Deadbolt shocks for what they are. | |
05-01-2015, 06:39 PM | #19 |
| Re: Deadbolt vs Falken G6 Good point thanks for the input. Should be ordered before the weekend is over.
05-02-2015, 08:02 PM | #20 |
I love the single spring setup as I explained earlier. Shocks leak but most do anyway. I only run enough oil to lubricate the o-rings.
Deadbolt vs Falken G6 - Similar Threads | ||||
Falken G6 | CKRC Hobbies | CKRC Hobbies | 0 | 07-30-2014 11:27 PM |
SCX G6 Falken | odogfish | Axial SCX-10 | 7 | 07-27-2014 10:56 PM |
g6 falken edition | snowman9031 | Axial SCX-10 | 24 | 06-20-2014 11:31 AM |
Axial Falken SCX10 ? | ngward79 | General Scale Talk | 46 | 04-28-2014 06:01 PM |
