08-30-2014, 05:12 AM | #1 |
Rock Crawler Join Date: Jul 2013 Location: Kansas City
| axle housing needs replaced looking at options
ok the plastic housing centers are pretty thin will be replaced over winter. I was wondering if anybody knows if RC4WD T-Rex 60 will work on the scx10 with out much hassle? https://store.rc4wd.com/T-Rex-60-Pla...ts_p_1013.html this is what I am looking a There is not much info. |
08-30-2014, 05:17 AM | #2 |
RCC Addict Join Date: Dec 2007 Location: London
| Re: axle housing needs replaced looking at options
In One Word 'Currie' The End |
08-30-2014, 06:23 AM | #3 |
Quarry Creeper Join Date: Oct 2011 Location: Land of earthquakes
| Re: axle housing needs replaced looking at options |
08-30-2014, 06:48 AM | #4 |
so these are modded wraith housing to fit under the scx10? if that's the case I'm buying them now! that is slick
08-30-2014, 07:13 AM | #5 |
Here is what I'll probably end up getting. unless I win the lotto. T-Rex 60 Front & Rear Plastic Complete Axle |
08-30-2014, 09:14 AM | #6 |
Pebble Pounder Join Date: Nov 2010 Location: wyatt
I run t-Rex 60 in an scx based tuber. They look good and for light use they are bad ass, however I have broken knuckles and housings, as well as a number of shafts attempting things I should not have. Overall I am happy with them but I'm not sure I would buy another set of them. Sent from the drivers seat of scx10 |
08-30-2014, 10:36 AM | #7 | |
| Re: axle housing needs replaced looking at options Quote:
Ok, having said that, would you be able to recommend them or not. I tend to drive a little more careful now days since I'm having to replace wore out parts from driving like a tool. How tough is the housing material? | |
08-30-2014, 11:56 AM | #8 |
Housings are tough, I would recommend them to a careful driver but would suggest aluminum knuckles and C-hub supports. Worst part about them is availability of replacement shafts. Sent from the drivers seat of scx10 |
08-30-2014, 01:30 PM | #9 |
I take it that they are not interchangeable with any other axles?
08-30-2014, 01:36 PM | #10 |
No, shafts are proprietary to these axles Sent from the drivers seat of scx10 |
08-30-2014, 01:43 PM | #11 |
Quarry Creeper Join Date: Aug 2014 Location: Mission viejo
Probably find a take off set on eBay for a few bucks. I beat the hell out of mine and they've lasted a long time. If I were to upgrade, it would be currie or go home
08-31-2014, 05:39 AM | #12 |
axle housing needs replaced looking at options - Similar Threads | ||||
Truss options with VP SCX10 diff housing | dextan22 | General Scale Talk | 1 | 04-17-2014 03:55 PM |
Using a front axle housing on your rear axle | nstn8 | Axial XR10 | 2 | 10-25-2011 07:32 AM |
Broken front Axle Replaced !!! | kknigh | General Crawlers | 5 | 05-13-2006 07:12 AM |
Axle housing | nd4spdbh | Tamiya TLT Crawlers | 10 | 08-05-2005 01:58 PM |
