09-02-2014, 09:15 AM | #1 |
| Harley's Mighty SCX 1.9 Wraith Recently Mighty1 posted a thread rebuilding his 1.9 Wraith based truck, but instead of the typical way of putting SCX axles under a Wraith chassis he decided to adapt a SCX chassis to the cage. So simple! His thread can be found here --> CLICK! So last night while working in the shop I grabbed some pieces from the parts piles and started to throw something together. Here is an intro video to the project. |
09-02-2014, 09:18 AM | #2 |
| Re: Harley's Mighty SCX 1.9 Wraith
The basis of this build is easy of building and easy access. Steve integrated a flip top, making everything under the chassis super easy to access. For my version I made an incredibly simple bracket to mount the cage off of. A piece of 16 gauge steel with two little bends and 4 holes. 10 minutes worth of work. It mounts to the rear most hole of the chassis. The cage lays down on the chassis at a nice height. But the best part is that it flips right up. |
09-02-2014, 09:22 AM | #3 |
Now there was a little work done to make sure that everything cleared the SCX shock hoops. I wanted to use these hoops instead of the integrated Wraith hoops so that I could maintain the flip top. It required a little dremel work on the chassis was all. The outer frame rails in the rear were removed. Here you can see the rough cuts. The front frame rails and shock mounts were also removed. The rear shock mount piece was removed, and then I cut off the actual shock mount pieces so I could reinstall the cross piece for extra rigidity in the chassis. Lastly, since the lower section of the chassis is only used to mount the Wraith skid plate, it was removed to increase clearance. Last edited by Harley; 09-02-2014 at 09:26 AM. |
09-02-2014, 09:25 AM | #4 |
For the body, at this time I am planning to use this Proline JK Wraith body. It has a nice proportional look and fits well. The wheelbase when matching to the wheel arches sits about 11.75" total. |
09-02-2014, 09:31 AM | #5 |
| Re: Harley's Mighty SCX 1.9 Wraith SORRCA Another part of this build is that now that it uses frame rails, it is easy to say that it is class 2 legal. So from here on out, I will make sure to base my decisions on making sure I keep it legal and start raising the scale points of the truck. |
09-02-2014, 06:24 PM | #6 |
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
Interesting build. Looks like fun. Especially if you can build it with mostly over the counter parts. ..Uploaded from the lab @ the C.I. Compound... |
09-02-2014, 08:09 PM | #7 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
I'll be watching for sure. I've had this in mind since before the "Mighty Tack"... but I haven't had time in my weird ass 60+hr work weeks as of late. I'll follow your build closely.
09-02-2014, 09:09 PM | #8 |
Quarry Creeper Join Date: Nov 2012 Location: spanish fork
Pretty cool idea
09-02-2014, 09:41 PM | #9 |
Newbie Join Date: Jul 2014 Location: Central Kalifornia
Will be interesting to see the final product!
09-02-2014, 09:49 PM | #10 |
Quarry Creeper Join Date: Mar 2014 Location: Athens, Al
This looks like its gonna be awesome. I got to lookin around after I read this thread and I have a the stuff lying around for this. May have to build one too.
09-02-2014, 10:08 PM | #11 |
I got the truck to a roller tonight, using only links I had laying around the shop. Regular G6 links for the uppers, and long and short Traxxas pushrods for the lowers to dial in the wheelbase a little closer. I used stock SCX shocks for the time being. I'm hoping to get my final ride height down to more of a 50/50 setup however. Right now it's taller than I'd like. Granted once I get all the junk in the truck I'm sure it will drop a little. |
09-02-2014, 10:40 PM | #12 |
Love the 1.9 Wraith and I agree, Mighty1's SCX frame is a cool idea. Looking forward to the awesome that this is destined for.... |
09-02-2014, 11:07 PM | #13 |
Cool build... nice work I like the combo chassis design. And prefer the look of the 1.9 tires. tho' your axle width looks too wide for my liking. But then... I'm a scale addict and even think my scx-10 axles are to wide for true to scale proportions. those the Wraith axles ? look forward to your completion... and hopefully you'll post a video of it rolling |
09-03-2014, 06:28 AM | #14 |
Probably a dumb question but I haven't seen it covered yet. What holds the wraith cage down in the front? Anything or is the hinge setup tight enough you don't have to worry about it?
09-03-2014, 08:12 AM | #15 | |
| Re: Harley's Mighty SCX 1.9 Wraith Quote:
09-03-2014, 08:15 AM | #16 | |
This is with 475 or 600 front hubs, 225 rear hubs. All f which will get adjusted when the new wheels and tires come in. | |
09-03-2014, 08:20 AM | #17 |
I have looked at your pictures and information and you have my approval. Continue on as planned.
09-03-2014, 08:25 AM | #18 |
| Re: Harley's Mighty SCX 1.9 Wraith |
09-03-2014, 08:45 AM | #19 |
09-03-2014, 10:18 AM | #20 |
Harley's Mighty SCX 1.9 Wraith - Similar Threads | ||||
Harley's Wraith Moonbuggy | Harley | Axial Wraith | 44 | 11-09-2016 07:35 PM |
Harley's Wraith Sportsman | Harley | Axial Wraith | 123 | 01-21-2012 05:35 PM |
Harley's Descender SCX-10 | Harley | Axial SCX-10 | 22 | 03-26-2009 09:45 PM |
