09-04-2014, 07:52 PM | #1 |
Newbie Join Date: Apr 2014 Location: auburn
| Project Tide Me Over
Im new to the forum posting wise but have been lurking for a while, thought I would post up what I have been up to lately. I am an avid Jeeper and frankly am a bit obsessed, but recently married and moved into a one bedroom apartment 3 states away from my garage, so the real toy stayed behind, gathering dust... [IMG][/IMG] I also sold off all of my dirtbikes and other toys so the wife let me get my one toy to tide me over, I went to the local hobby shop and picked up one of the new Deadbolts, and went straight to my father in laws house for some crawling. He has a course he built in his back yard for his wraith. This first thing I noticed out of the box, the links are terrible, the rear axle was able to work its way forward over and inch and touch the rock sliders within the first few minutes. Then came the steering, I could turn one wheel while the other stayed still, making picking lines lots of fun! So I hit the garage and machined myself some rear links! Solid 1/4 inch aluminum [IMG][/IMG] I love how it leaves dents and scratches like a 1:1. I also built them to give it a little stretch, simply because I cant leave things alone And yes I know I'm pushing the limits of that drive shaft, kleenex springs to hold it in place for the win! [IMG][/IMG] Gotta love that departure angle! |
09-04-2014, 08:04 PM | #2 |
| Re: Project Tide Me Over
Next up was the steering, I went the easier route with this and decided to just use all thread and revo ends, but I forgot the tube on top before I bent it out Ill fix that at a later point. These simple fixes made this truck 1000% better and more driveable, Its very stable and able to fairly easily keep up with the wraiths that I run with. I'm running it on a 3000 pack and can get over an hour of crawl time in fairly easily. Next I did the usual mods, moved the electronics to the back, and the battery to the front/middle. I had the battery all the way in the front between the frame rails, but it got a bit front heavy, so I moved it to perpendicular to the frame rails. much better! [IMG][/IMG] [IMG][/IMG] I also added some extra lights to the bar and made it functional, I ended up using some small LED's that were for my 1:1's rock lights and putting them in the light rack, easy install for a big improvement. [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] I also did a bit of trimming on the stock tires for just an added bit of traction, and man do the hook up for stock tires! [IMG][/IMG] |
09-05-2014, 11:10 AM | #3 |
I did find a nice open field behind our apartments that nobody seems to know who it belongs too, sounds like an open invitation to me! There was also a huge pile of broken down concrete so that was perfect to start building a course. [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] I would also love to build it into a mini-me of my 1:1, but would have no idea where to start with that. Let me know if you guys see any flaws or suggestions. |
09-05-2014, 04:19 PM | #4 |
I would also love to build it into a mini-me of my 1:1, but would have no idea where to start with that. Let me know if you guys see any flaws or suggestions.[/QUOTE] Gmade has a Cj 2?/3? Something like that. That might get you closer. Get a body, build from there. |
10-03-2014, 10:56 AM | #5 |
Im personally looking into something more custom A custom tube chassis buggy of sorts, Ive actually been drawing it up and came up with something like this. [IMG][/IMG] [IMG][/IMG] Thats with my stretch rear end and 2.2 tires. This would give me sort of a southern rock bouncer look mixed with the tube chassis crawler. Im thinking that I would make this out of 1/4 styrene rod and just sheet styrene for the body pieces. I would normally build it out of steel but I dont have any of my welding equipment with me at college, and the wife doesnt want me spending money on buying any of it again. I believe that if I put enough triangulation in the tubes and used a proper MEK glue It would be as strong if not stronger then the stock roll cage bars. Let me know what you guys think, any comments are appreciated. |
10-09-2014, 10:57 AM | #6 |
Not sure if anybody is reading this but I will still post up any progress just in case. I decided to just jump in and try my hand at building a body out of styrene. Now I have 0 experience with this stuff so be easy on me I started out still working off the drawing that I had made and printed out the lay out of the cage pieces. [IMG][/IMG] After a few days of trying to cut all the pieces and get the cage built, all I ended up with was a bunch of pieces and now way to connect them, I couldnt figure out how to get this plastruct to work on the tube... oh well Ill figure that out later. I decided to move on to the body pieces because I knew I could get the body pieces to stick. I forgot to take pictures during the first parts of the build So ill just pick up where I started. [IMG][/IMG] [IMG][/IMG] I decided to use the stock body pillar mounts just to make things a little easier on myself, In the long run I dont know if this will end up being a good idea since I have to drill holes in the hood, and If you are slightly dyslexic like me, youll be drilling a few times. The hood will probably end up being remade in the future but for now I just wanna get it together and then I can do the finishing touches. [IMG][/IMG] Just one big flat hood, just like the real deal! Notched out the hood for the highline fenders I had to do for tire clearence. Keep in mind I am trying to keep the low center of gravity look that my 1:1 has going on. Here it is size comparison to the stock deadbolt body [IMG][/IMG] I made a mock-up grill while I go about making the actual one, thats NOT going to be fun! a lot of slats in the old jeeps. At this point I got restless and couldnt stop myself, I finished out the rear of the body. So much for the drawing that I made up. [IMG][/IMG] And the mandatory flex shot. Everything clears and I think its starting to look pretty decent. [IMG][/IMG] |
Project Tide Me Over - Similar Threads | ||||
roll tide | larimorej | Alabama | 3 | 01-10-2012 07:55 PM |
Crimson Tide Theme 1950's Pick Up | nascarkeith | Paint and Body | 2 | 02-14-2010 02:32 PM |
Rooooll Tide Roll | hardhead | Chit Chat | 4 | 09-01-2008 06:35 PM |
Building a AX10 at the beach when the tide is out. | lilskip | Axial AX-10 Scorpion | 18 | 04-13-2008 08:45 AM |
Royal Palms State Beach / San Pedro Tide Pools | _BEN_ | California | 7 | 03-29-2008 08:05 PM |
