Thread: RCBros or Vanquish CMS?
Old 09-05-2014, 06:59 AM   #1
Default HandBros or Vanquish CMS?
I have almost completed the build and then install of my front Vanquish SCX Currie Axle. I have in hand, the RCBros CMS. In your opinion would you chose the RCBros or the Vanquish CMS / Front Bumper Mount and Panhard Bar? Having never installed a CMS, are they pretty straight forward? I ask because there are no instructions to be found for the RCBros as we all know. Obviously the VP CMS can be installed blindfolded and with the finger.
I want a set up that will be the most friendly for bump steer gremlins. If it matters, i am running Axial CVD's and King 100mm in the front.
Thanks for any input.
cmbscx10 is offline   Reply With Quote
Old 09-05-2014, 07:17 PM   #2
Default Re: RCBros or Vanquish CMS?
I have the vanquish one and I like it alot.
Tmaxxed is offline   Reply With Quote
Old 09-08-2014, 02:36 PM   #3
RcBros Hobbies
RcBro's Avatar
Vanquish, The RcBros (if that truly is what you have) is only intended for leaf sprung suspension.
RcBro is offline   Reply With Quote
Old 09-08-2014, 04:08 PM   #4
Wholly cow Im such an idiot. I apologize to all that read and responded. I actually have a handbros CMS.
Old 09-08-2014, 07:07 PM   #5
Default Re: HandBros or Vanquish CMS?
Due to having the Currie Axles, I would go with the Vanquish CMS and Panhard bar. It is designed to work with the Curries vs. having to make the handbros parts fit the Curries.
k7zpj is offline   Reply With Quote
Old 09-08-2014, 07:48 PM   #6
RcBros Hobbies
RcBro's Avatar
No worries bro, your not the first
As posted above the VP set may be the best for this application
RCBros or Vanquish CMS? - Similar Threads
Vanquish Product's CMS Hammer! Axial SCX-10 25 07-13-2014 10:29 PM
Vanquish cms issue! 509hooligan Axial Wraith 24 04-25-2013 04:28 PM
