09-08-2014, 05:26 PM | #1 |
Newbie Join Date: Nov 2012 Location: Australia
| Chassis links Asiatees or Vanquish
Hi guys I'm looking at upgrading my chassis links and steering link to metal ones on my jeep these are the ones im looking at Axial SCX10 Alluminum Front Chassis Links Parts Tree - 3Pcs Set Black GPM Racing SCX049F Axial SCX10 Aluminum Steering Link - 1set Silver GPM Racing SCX160 Axial SCX10 Alluminum Rear Chassis Links Parts Tree - 4pcs Set Purple GPM Racing SCX049R or http://www.ebay.com.au/itm/360995579...84.m1423.l2649 Which ones would you get and why? are they the same quality? |
09-08-2014, 06:19 PM | #2 |
RCC Addict Join Date: Oct 2012 Location: Norcal
| Re: Chassis links Asiatees or Vanquish
Vanquish is always better! One word, Quality. Don't forget if you don't have Currie axles, you don't want those links. RC Accessories - Axial SCX10 Parts - Titanium Links - Vanquish Products It's also a preference for people but you may want to go with a four link up front. |
09-08-2014, 06:23 PM | #3 |
Do not buy any links with solid rod ends on them... Eventually they will fail and the link itself will be useless. Do use/make any link with traxxas revo/jato(m4) rod ends, such as the VP and others use. |
09-08-2014, 06:30 PM | #4 |
| Re: Chassis links Asiatees or Vanquish What meatwad said, plus 100% of the time tolerances are not that great.
09-08-2014, 06:45 PM | #5 |
Thanks for the help guys ill go with the ones Norton put a link for. Also what shocks are you guys using I have been told the gmade 103mm shock is a good choice to get, is that right?
09-08-2014, 07:00 PM | #6 |
rc4wd sells metal rod ends... and for the scale look... they replicate a heim joint fairly well. I like that they have stop/adj. nuts on the threads. Just be aware of the thread sizing wanted. M3 is more common with most 6mm pre-threaded rod and the Axial link rods. Metal Rod Ends chinese made... so durability and consumable life... could be a hit or miss ps: take note that there are straight ends and angled ends. shocks ? I like the traxxas 100 mm big bores. I have the plastic cheapo units. But if alloy is your thing they're available for mo' $ I like how the internal bladders work. (nestled in the upper cap) They work well if lighter rated coil springs are used. My rig weighs around 9 - 10lbs. A 100 mm shock is about the limit for the SCX-10 chassis any longer and the upper shock mount would need be raised. My BB and Losi white coil springs sit about 50% squat for the chassis ride height. Suspension droop potential is more valuable for a technical crawler then total compression. 'least IMO Last edited by TacoCrawler; 09-08-2014 at 08:04 PM. |
09-08-2014, 07:14 PM | #7 |
The G-Made Zero's or the Aerations are nice. The Piggybacks seem to big for a scale look. I would also buy 93mm instead of the 103 mm's. 103's are nice for a Wraith but a little tall for a SCX10. The Chevy on the left has 93mm and the Yota has 103's. I went back to 93's on the Yota and was much more stable. |
Chassis links Asiatees or Vanquish - Similar Threads | ||||
vanquish incision chassis and links help? | perry3182 | Axial AX-10 Scorpion | 4 | 01-21-2010 07:58 AM |
