09-11-2014, 08:34 PM | #1 |
Newbie Join Date: Aug 2014 Location: selah
| flex
im looking for shocks that will give me great articulation. Any advice? Thanks in advance.
09-11-2014, 08:35 PM | #2 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
| Re: flex
103mm shocks are plenty.
09-11-2014, 08:38 PM | #3 |
Rock Crawler Join Date: Aug 2011 Location: south shore Ma
| Re: flex
There is a little more to it then just shocks but longer ones will help some. If you angle them so the top side of the shock is more towards the center of the truck that will help out too.
09-11-2014, 09:28 PM | #4 |
| Re: flex
I run the inexpensive Traxxas ( T/E Maxx ) 100mm Ultra XXL big bores. They can be found/purchased for $ 25. for four (plastic bodied) If set up properly... they work purdy good. rebuilding is simple... and Traxxas BB re-seal cartridge kits are inexpensive as well. Mine are the original plastic bodied CO's But they are also available in alloy if one wants that. ( mo' $ ) * * these are designed differently. so see my later post for more details. I run the Losi white coil springs (2.75") on mine. ^ there is also a grey 2.75" C spring that Losi offers. and it is rated lighter ( 1.6lb ) then their white C spring. part # is likely... 5146 I use the Traxxas cheapo snap in pre-load shims on mine where wanted. But pre-load shimming is not a necessity. Both upper and lower spring seats fit fine with the Losi coil spring diameter. I maintain my suspension ride height setting somewhat squat 50/50 up/down travel. The 2.75" Losi coil springs have always remained positioned in both their upper and lower seats. Gravity and time are not consumable friendly... So... to insure my springs do not settle prematurely... I always store my rig on a chassis supported stand. The Traxxas Ultra XXL BB's may not be scale looking to some. But they aren't excessively over sized IMO. Regardless... they are worth it, when considering their performance. here's a look for yerself... here's a video carrying the rear tire at max articulation... honcho on the wall - YouTube Last edited by TacoCrawler; 09-14-2014 at 10:02 PM. |
09-11-2014, 09:43 PM | #5 |
Rock Stacker Join Date: May 2013 Location: Marietta
| Re: flex
Those are some great shots TC. Hoping my rig will flex like that when i get it done.
09-11-2014, 09:48 PM | #6 |
| Re: flex Don't let the snare of tons of articulation grab hold of you! I have found that tons of articulation can be more of a hindrance than an asset. That said I run stock scx10 shocks in both my rigs, with the limiters removed. Enough articulation, but not to much.
09-12-2014, 05:13 AM | #7 |
Quarry Creeper Join Date: May 2013 Location: Knoxville
| Re: flex
Does it have to be Traxxas BB shocks? I have a set of tmaxx stock shocks laying around would they work?
09-12-2014, 06:29 AM | #8 |
Pebble Pounder Join Date: May 2014 Location: fernandina beach
| Re: flex
I don't want to confuse anyone, but there are two different shocks from Traxxas that are loosely referred to as "big bore" shocks. I believe the shock that Tacocrawler is using is called the Ultra shock and it comes stock on most Traxxas vehicles. The Traxxas Big Bore shock is sold as a replacement shock, although is does come on the Slash 4x4 Ultimate. In the picture below I lined up three shocks on a 2.2 tire. The shock on the left is an Axial Wraith shock. The shock in the middle is a Traxxas Ultra shock, upgraded with STRC parts. The shock on the right is a Traxxas Big Bore shock. I agree with Tacocrawler that the Ultra shock is a very capable shock for rock crawling, cheap but very tunable, with plenty of parts available. My advice: go to the Traxxas website and down load the PDF file on this shock to get the right part #'s. The Ultra shock and Big Bore shock are different shocks and the parts do not interchange! |
09-12-2014, 07:34 AM | #9 | |
Rock Stacker Join Date: Sep 2012 Location: Waterloo
| Re: flex Quote:
Look like these Although I believe these are just the upgrade to the Ultra Version shocks to be honest. Last edited by Stoph; 09-12-2014 at 07:37 AM. | |
09-12-2014, 12:40 PM | #10 |
Newbie Join Date: Nov 2011 Location: Colorado Springs
| Re: flex
The traxxas big bores are non threaded aluminum body and caps, the traxxas ultra shocks are non threaded plastic body and caps. You can buy aluminum caps and body's for the ultras, and the ultras have a bigger bore than the "big bores" Sent from my iPhone using Tapatalk |
09-12-2014, 09:32 PM | #11 |
Rock Crawler Join Date: May 2009 Location: Texas
| Re: flex |
09-12-2014, 10:00 PM | #12 | |||
| Re: flex Quote:
Defined by being black plastic, smooth bodied with a bladder in the upper cap and a O-ring cartridge at the lower end. Plastic snap on shims are required... if any additional pre-load is desired. Tho' not a necessity if using the Losi coil springs. These are also produced in a grey bodied version. ^ TRA 3762 A TRA 4962 are the alloy Big Bores and utilize a different construction design. And are produced to offer a supposed upgrade to an alloy bodied shock. Smooth bodied... but no cartridge on the lower end. Maybe this link below can help clarify the differences... !? * Big Bore and Ultra Shocks are Different Sizes! - Traxxas E-Maxx @ URC Forums either 100mm traxxas shock will work... But the TRA 3762 Ultra XXL's are easier to rebuild. And cost less. * There is a slight diameter difference between the TRA 3762 and TRA 4962 BB alloys. Noted in the link above. This could be a critical difference of how the Losi coil springs fit the lower seat/cup. I do not have the TRA 4962 alloy shocks so I cannot say if the Losi coil springs will fit the lower seat/cup on those. -------------- Quote:
as compression of the coil springs will limit the shocks travel when compressed fully. ^ would only work on the TRA 4962 Alloy bodied big bores * The mini T spring use... would not work on the TRA 3762 Ultra shocks. As the lower cartridge is flush to the shock's body diameter. --------------- Quote:
although I must say there were several different versions of the T-Maxx since it's inception. I have the 1st original T-Maxx version... and those are the shocks that I utilize. (TRA 3762) Last edited by TacoCrawler; 09-12-2014 at 10:18 PM. | |||
09-15-2014, 05:13 AM | #13 |
| Re: flex
Where do you get the Losi white Springs?
09-15-2014, 10:29 AM | #14 |
| Re: flex
purchased mine from my LHS It could be that one of the vendor's here offers them FS google search nets... Losi website if wanting a lighter rate coil 1.6 google search for Losi # 5146 Losi website Last edited by TacoCrawler; 09-15-2014 at 10:34 AM. |
09-15-2014, 11:05 AM | #15 |
| Re: flex
Horizon hobbies says unavailable, Losi says buy from retailer
09-15-2014, 12:38 PM | #16 |
| Re: flex
google LOSA5147 = 1.8 or LOSA5146 = 1.6 they can be found if ya make an effort. Oh I called Horizon Hobby... The only 2.75" Losi spring still being mfgr'd by LOSI is the 2.0 rated coil spring LOSA5148 (yellow) Horizon says those are in stock. Not sure if they would be too stiff... so guessing it would depend on the weight of your rig. Locating the white 1.8 or gray 1.6 would require locating old stock. I'm checking my LHS to see if they can locate/obtain those. My LHS has one pair of the LOSA5147 in stock... but two sets would be required. I'll post up if I can locate those. Check here... http://www.helidirect.com/losi-275in...te-p-14874.hdx ^ just called them... and they say they have 3 pair left. get 'dem while ya can Last edited by TacoCrawler; 09-15-2014 at 02:18 PM. |
09-15-2014, 01:25 PM | #17 |
Quarry Creeper Join Date: Dec 2013 Location: Atlanta
| Re: flex
I found some on thebay for pretty cheap a while ago
09-15-2014, 04:44 PM | #18 |
| Re: flex the only LOSA5147's selling on thebay, that I found... are listing's from the UK. I'll bet there's plenty of old stock floating around stateside... Just gotta call up every local hobby store, to see if they still have some on their shelves. ie: the heli-direct website... normally only sells helicopter stuff. But they once tried including RC cars... so that's why they have left-over Losi parts. Guy there was hoping I wanted to buy all their NOS Losi inventory |
09-17-2014, 05:44 PM | #19 |
| Re: flex
awrite... since I'm always seemingly promoting the use of the low buck Traxxas 100mm Ultra XXL's and the Losi coil spring, that was used, has become a discontinued product. Thought I had better come up with a replacement coil for these low buck Traxxas Ultra shocks. Sooo... Here's an alternative replacement... ya I know... the package say's "white" but instead... they're black !? ~they do have white paint markings tho'~ ...it's equally rated at 1.8 and coil ID/length fits the Ultra's perfectly. The spring's over-all length is maybe 2mm longer. So maybe the actual spring rate would be technically higher guessing 1.82 - 1.84... can't say fer sure. Should work for the replacement NOS LOSA5147 white 1.8 coils. I think black looks better anyways. something to note the Traxxas 100mm Ultra XXL Shock installed to a lightweight SCX-10 chassis may not be the best choice unless lighter weight coils could be found. This spring rate works well on my rig. weighing in at around 9-10 lbs ^ incl. weighted wheels and beef tubed axles. and home made Fr/Rr bumpers, sliders plus electronics. so these will work well for my circumstance. And should suffice for rigs weighing 8-10 lbs Last edited by TacoCrawler; 09-17-2014 at 06:32 PM. |
10-03-2014, 06:11 PM | #20 |
Newbie Join Date: Dec 2012 Location: latonia
| Re: flex
Are the stock springs on these traxxas shocks too stiff im guessing??? Cause ive considered this for a while now buying a set of t maxx shocks so I have 8 shocks to do both of my scx10s.. so ill need these losi springs ??? Are the stock t maxx shocks the right ones to use with the 1.8 rate losi springs??? 3 questions I know but just want to be sure on all 3 questions....
flex - Similar Threads | ||||
Now that's some flex | Mayhem Eng. | Chit Chat | 2 | 11-10-2011 09:01 AM |
more flex | Moparguy | 1.9 Scale Rigs | 5 | 01-21-2011 12:42 PM |
How to get more flex | 98sierra | Axial SCX-10 | 25 | 01-13-2011 09:26 PM |
Will this get me more flex? | rwagner | Losi Mini-Rock Crawler | 3 | 12-30-2010 11:13 PM |
flex | kaikea | Axial SCX-10 | 11 | 04-16-2009 04:56 PM |
