09-17-2014, 07:10 PM | #1 |
Pebble Pounder Join Date: May 2014 Location: Escatawpa
| Robinson racing question
So I just ordered a spur gear, idler, and outdrive gear from Robinson racing. Will the set screw work with it or is there something else I need to order? Sent from my iPhone using Tapatalk |
09-17-2014, 07:14 PM | #2 |
| Re: Robinson racing question
set screw will work, That's what I've always ran. Mostly with MIP shafts.
09-17-2014, 07:42 PM | #3 |
Yeah the MIP shafts will be next Sent from my iPhone using Tapatalk |
09-17-2014, 07:54 PM | #4 |
RCC Addict Join Date: Aug 2012 Location: The Garage!!!
I used rr output gear at first but broke it then went to HR gear with stock outputs with holes so can run "set screw"all way through output! The grub screws work loose with bigger power...be sure clean with alcohol use blue thread lock let set up overnight! |
09-17-2014, 08:49 PM | #5 |
Ok thanks so the set screw will be fine. Good deal Sent from my iPhone using Tapatalk |
09-17-2014, 10:01 PM | #6 |
Rock Crawler Join Date: Oct 2011 Location: Fairfield
A lot of people are doing the HR's or the RR without the output drives. Cheaper to fix a output shaft than the whole unit, you also keep those through pin style screws.
09-18-2014, 03:12 PM | #7 |
Ok I'm Confused now. Basically is it good to Be running the steel outdrives? And what else am I Going to need to install these? Sent from my iPhone using Tapatalk |
09-18-2014, 08:03 PM | #8 |
The rr one piece is complete with outputs but no holes for set screw! The hr or rr gear is best because you retain the outputs with holes in them for screw to go through output instead of using grub screw to hold shaft to outputs... Get this & call it a day! Hot Racing Axial SCX10 AX10 Wraith hard steel center gears set |
Robinson racing question - Similar Threads | ||||
Robinson racing steel slipper question | Riddler6.7 | Axial Wraith | 4 | 11-21-2013 04:14 PM |
question for you all on the Robinson racing slipper? | champ198 | Axial Wraith | 8 | 07-04-2013 06:09 AM |
Robinson racing upgrade question | bagged86 | Axial Wraith | 1 | 04-28-2012 04:08 PM |
Robinson Racing gear question | bagged92sdime | Traxxas Crawlers | 8 | 04-21-2007 04:33 PM |
