Thread: Scx10 project. Need opinions
Old 09-25-2014, 05:21 PM   #1
Talking Scx10 project. Need opinions
Hey
So I'm about to make the jump to an scx10 dingo kit. My plan is to use everything stock to start out and replace whatever becomes weak points. I have a good servo and radio system, the question is the motor.
I have a castle 2400kv 4 pole brushless motor and a MMP speed control, both with fans. I am able to program it via the esc and through my spektrum DX4S to be as smooth as possible. What are your opinions of this setup and what kind of gearing should I be running on 2s and 3s? The more help the better.
Drewmtb29 is offline   Reply With Quote
Old 09-25-2014, 05:59 PM   #2
Default Re: Scx10 project. Need opinions
interesting project!
I would like to use a SC411. which i used in my short course before. also 4 pole 3400KV.But i do not have a controller. And before that i think it would be get the week parts upgrades.
Pls go ahead and share!
Herymet is offline   Reply With Quote
Old 09-26-2014, 11:04 PM   #3
So I picked it up today and got this far in the build. Anyone else notice with stock axels that when you get to a certain point the get tighter then loosen up as you keep turning.. Then repeat? It's like one spot that is tighter on the diff.
Opinions?
Old 09-27-2014, 04:50 AM   #4
Some do that, and the danger is not in the tight spot, that will break-in over time. The danger is in the loose spot because that means that the gear teeth are not fully engaged, that's what leads to breakage. Search some of the articles on using shims, but I would let it break-in first. About the engine, Castle makes some fine engines, I run them on my shortcourse buggys, but they aren't sensored. The MMP accepts a sensor input, though, so you are good there. See how it works for you first, but it may cog real bad at low throttle, which is where a crawler is at most of the time. It don't matter in shortcourse because the throttle is either on or off, but cogging with a 3S or 4S battery can lead to premature breakage, also its not very scale because 1:1 trucks don't do that unless they're in real trouble.
mr dave is offline   Reply With Quote
Old 09-27-2014, 06:20 AM   #5
What do your mean by cog??
FlexinFL is offline   Reply With Quote
Old 09-27-2014, 07:15 AM   #6
Cogging is like hesitation,sputtering throttle at low speeds almost as if drivetrain in bind! The non Sensored motors are designed for racing(go fast)applications. The Sensored motors have very smooth low end throttle! It's almost impossible to crawl with anything that's not Sensored! The esc is what I run along with 3100-3300kv Sensored motors with great results...
sic1to is offline   Reply With Quote
Old 10-04-2014, 11:40 PM   #7
Some pics of running it.
Ordered some stuff...
-4" rc4wd light bar.
-Proline F250 cab.
-axial roll cage.
-STRC 3 and 4 link parts. 4 link on back
Going to run the stock 3 link up front till I can shorten up the motor... What is a good reccomendation? Needs to be capable of 3S and easy on the wallet.
Anything else worth doing?
I'd like to make some sort of sleek protection piece for the front and rear diffs.. Ideas?
Old 10-05-2014, 05:34 PM   #8
what that motor?
Old 10-05-2014, 05:43 PM   #9
Castle 2400kv.
Would a turnigy track star 2100kv sensored motor be a good option?
Old 10-05-2014, 05:45 PM   #10
You should switch the battery positions...you have too much weight in the back. Put the main battery where the esc is now, and move the esc to right behind the trans on it's own bracket.
Johnnysplits is offline   Reply With Quote
Old 10-05-2014, 05:53 PM   #11
Default Scx10 project. Need opinions
That's what I'm going to have to do since I have a proline f250 coming and the rear roll cage.
Old 10-07-2014, 08:30 AM   #12
Looking forward to a running video of this beast
thehighroad is offline   Reply With Quote
Old 10-07-2014, 08:33 AM   #13
That's in the works. Hopefully I can finish it up before the winter time. Don't plan on doing too much snow driving. Gets to chilly here in Canada.
Old 10-07-2014, 08:34 AM   #14
Update also..
Battery is moved to the front. Fabricated my own esc mount and waiting for parts this week. Turnigy Trackstar 13.5t sensored bl motor on the way from Hobbyking so that will be a while longer
Old 10-08-2014, 05:18 PM   #15
what's servo you use?
Old 10-08-2014, 06:36 PM   #16
Blue bird metal gear waterproof. Forget the model. Cheap from hobbyking and running strong for 2 years
Old 10-08-2014, 07:01 PM   #17
Solar 772 is $23 also 417oz @ 7.4v but not waterproof I always wateeproof all my trail servos myself.
Old 10-08-2014, 07:04 PM   #18
Got lots of parts arriving soon. Pictures to follow
Old 10-08-2014, 07:39 PM   #19
If you have not already put steel gears in the trans you might want to look into that. Just my 2 cents
mark32 is offline   Reply With Quote
Old 10-08-2014, 07:41 PM   #20
Have not done that. I know it's a good idea and will eventually need to happen. Any specific brand?
Tags
brushless, crawler, dingo, gearing, scx10
Scx10 project. Need opinions - Similar Threads
project cxt opinions? smokinloon South Carolina 5 04-01-2014 05:53 AM
Tuber Project, Need Opinions jagg Tamiya Clod Buster 53 03-13-2008 09:29 PM
Not a crawler project but looking for opinions sniper Chit Chat 23 12-13-2007 08:31 AM
TLT Project Opinions joesbruiser Tamiya TLT Crawlers 2 12-27-2006 02:32 PM
Need opinions on clod project suzukiltd Tamiya Clod Buster 1 01-23-2005 01:33 PM
