Thread: G6 differences
Old 10-03-2014, 05:46 PM   #1
Default G6 differences
is the differences in the falken G6 rig and the C/R and the normal G6 the just the tires and body decals?
looking at maybe picking one up but not sure if there is any huge differences other than just decals and tires
champ198 is offline   Reply With Quote
Old 10-03-2014, 07:40 PM   #2
Default Re: G6 differences
The falken g6 and C/R rig have a different body, roll cage, and wheel base. The C/R is a little longer. The C/R also has functioning lights I believe while the Falken just has empty buckets. Also the Falken has the newer HD driveshafts 32p gears and updated slipper. I could be wrong but I don't think the C/R has those. When you say the "normal" G6, if you are referring to the one that's white on the box, that one is a kit. It does not have the updated driveshafts, 32p gears or slipper, but it does have aluminum steering and lower links as well as aluminum shocks. It's the same body as the falken but of course, as a kit it comes with the body unpainted.
crockins is offline   Reply With Quote
Old 11-15-2014, 09:09 PM   #3
I believe crockins is spot on. Wheel base depending on what body you want to run. My Falken g6 is stretched to 12.3" anyway like the Rubicon g6/Honcho with links upgrade and how extreme the fenders come cut on the rtr it still lines up and looks pretty good. I don't think you can go wrong either way. Happy choosing....
SoulofInsanity is offline   Reply With Quote
Old 11-15-2014, 09:34 PM   #4
The cr edition has a 12.3 wb as well.
CrawlCrest is offline   Reply With Quote
Old 11-15-2014, 10:41 PM   #5
Yeah it is. "Rubicon" lid is a 4 door so longer G6, C/R otherwise.
Old 11-16-2014, 11:22 PM   #6
The G6 (white one on the box) DOES come with a slipper as well as a slipper delete.
Hotrodvw is offline   Reply With Quote
Old 11-17-2014, 02:22 AM   #7
The G6 Wrangler and G6 Falken = 12.0" WB.
The Unlimited 4dr Jeep/CR edition and Trail Honcho = 12.3" WB
TacoCrawler is offline   Reply With Quote
G6 differences - Similar Threads
Differences? fivepointnine98 RC4WD Bully 11 03-04-2012 09:50 PM
1.9 to 2.2 differences? M109R General Scale Talk 8 09-15-2010 04:40 AM
What are the differences between the 3? Sydwaiz Axial SCX-10 7 01-06-2010 05:34 PM
Size Differences? notez2beat Newbie General 5 11-18-2009 06:28 PM
Differences between these two yokes billysnarf Newbie General 5 06-10-2009 09:15 AM
