10-19-2014, 11:43 AM | #1 |
Rock Stacker Join Date: Jun 2011 Location: East Wenatchee
| Universal Axles
I know the XR10 mod is the cheapest and probably the best route to go, other than the new 5mm Vanquish VVD's or Super 300s, but I don't have the money for the VVD's or Super 300s and don't feel like doing the XR10 mod again. I am trying to keep stock width as my next rig will be my C1 rig. I was looking into other options for axles and came across these. I know the Axial ones pretty much suck if you try to get a lot of steering out of them. Has anyone had any experience with these? How well do they turn? I am looking for better steering and a little better strength. If they are not worth it, I will just save for VVD's. STRC Heat Treated Carbon Steel Universal kit for Axial SCX10 (1 pair) (Black) |
10-19-2014, 12:29 PM | #2 |
| Re: Universal Axles
my Axial Uni's have held up for well over a year. But like anything that wears... will eventually be in need of a rebuild. Cool thing... the Axial Uni's have easily obtainable/inexpensive rebuild kits. I have increased steering as well partially due to clocking the front axle. And maybe some from the Axial 8* Chubs/knuckles. Having a better radio also allows for throw (EP) adjustments. Exaggerated steering is not really true to scale IMO But if you wanted more steering control... think about using the Under/Over drive gearing option for the axles. a taller gearing at the front axle will increase your steering control |
10-19-2014, 05:07 PM | #3 | |
| Re: Universal Axles Quote:
I have OD gears in my C2, they work well with my XR10 mod. I plan on doing the OD gears in my C1, but I still need a sharper steering option. Something that requires no modding is what I am looking for, like VVD's or S300s. My buddy always had pin problems with the Axial CVD's, while I realize good end points would resolve that issue, having 45-50 degree steering is nice. Which is why I was wondering if anyone has had experience with the STRC CVD's to see if they allow for that much steering and how well they hold up. | |
10-19-2014, 08:56 PM | #4 |
Pebble Pounder Join Date: Apr 2013 Location: Bonney Lake
| Re: Universal Axles
Ive had good experiences with rc4wd xvds for the scx10 and theyre cheep enough at around 45$ and allow 45* steering. Had em for a couple years and only snapped 1 shaft which was 10 to replace and kinda my fault for getting into a bad bind on the rocks. But your steering stops only allow for around 40-42* tops unless you mod the stock knuckles or get high steers.
10-19-2014, 09:31 PM | #5 | |
Hmm i might go with those.. im currently setup on 3s with a 27T but im going to a 35T on both rigs so hopefully i wont break em. 45* is enough for me. I do 50* with my xr mod and i dont have enough servo to bring it back with my 645mg. Ill look into those. Thanks for the input. Any input on the STRCs is still welcome as i wont be making this purchase for a while so all the info i can get would be great. | |
10-20-2014, 03:17 AM | #6 | |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
10-20-2014, 09:34 AM | #7 | |
RCC Addict Join Date: Jun 2006 Location: Durham, NC, USA
10-20-2014, 06:26 PM | #8 |
| Re: Universal Axles |
Universal Axles - Similar Threads | ||||
universal axles | krank22 | Axial Wraith | 5 | 04-19-2014 07:01 PM |
Installing AR 60 universal joint axles | moejean | Newbie General | 3 | 02-02-2013 04:21 PM |
Universal axles.. How long till people get stock? | Figjamjake | Axial Wraith | 71 | 03-21-2012 12:53 PM |
Wraith universal axles in stock | TW31 | Axial Wraith | 0 | 03-15-2012 03:29 PM |
Looking for XVDs or Universal joint axles | BrainDead | Axial Wraith | 2 | 01-18-2012 12:31 PM |
