01-18-2019, 04:48 PM | #201 |
Rock Crawler Join Date: Mar 2006 Location: Dogpatch
| Re: New G6 build
Got the shocks mounted.I put the Axial yellow springs on them. I had to swap out the lower Traxxas shock ball swivel with the Axial setup as the shock mount and suspension link mount would not fit in the SSD axle mount space. Sent from my iPad using Tapatalk Pro |
01-20-2019, 07:12 AM | #202 |
RCC Addict Join Date: Mar 2018 Location: Ocala, Florida, USA
| Re: New G6 build
Good looking rig brotha! I have been thinking about grabbing a set of Trx shocks for the family dingo. I haven't had one issue with the ones on my Trx. Would probably need softer springs tho. The dingo is 3+lbs lighter then The Trx. You had to use the whole axial end or just the pivot in the end?
01-20-2019, 10:39 AM | #203 |
| Re: New G6 build
Thanks for the kind words AH! Had to use the Axial Rod end and plastic ball,plus the Axial spring perch.Couldnt fit two Traxxas metal ball ends on SSD axle mount. The suspension arms have Traxxas Rod ends on them as well. |
02-01-2019, 07:31 PM | #204 |
| Re: New G6 build
Just placed an order from Tower Hobbies.Ordered a set of the Proline Mud Terrain tires and a Ford Raptor body.Didnt like the looks of the Duratrax Deepwoods tires,not scale enough I guess.Needed another body like I needed another hole in my head. As you guys know I love to paint lexan bodies.Since I got so many likes on my camel yellow Jeep G6 body way back when, you guessed it.A camel yellow Proline Ford Raptor it is. |
02-03-2019, 10:27 PM | #205 |
Newbie Join Date: Feb 2018 Location: brewster
| Re: New G6 build
I’m excited to see the body painted. I am also going to put a proline raptor body on my wroncho
02-06-2019, 05:50 PM | #206 |
| Re: New G6 build
Got some goodies in the mail yesterday.Mounted up the new Proline tires last night.Much better looking tire than the Deepwoods.Im sure they perform as good as they look. Tonight I trimmed out the new Proline Raptor body, will probably paint and mount that up this weekend. Sent from my iPad using Tapatalk Pro |
02-09-2019, 12:17 PM | #207 |
| Re: New G6 build
Got the Tamiya Camel Yellow sprayed on.I will do the black trim work on the outside.Using the overspray film as the mask makes this much easier.A steady hand with a new exacto blade helps too! Sent from my iPad using Tapatalk Pro |
02-09-2019, 12:59 PM | #208 |
| New G6 build
Black is painted. Time to start peeling mask away and see what we have! Sent from my iPad using Tapatalk Pro |
02-09-2019, 02:04 PM | #209 |
| Re: New G6 build
Presto-we have a Ford Raptor ready for decals! Sent from my iPad using Tapatalk Pro |
02-09-2019, 02:07 PM | #210 |
| New G6 build
And finished up with the decals applied. Will mount it later. Sent from my iPad using Tapatalk Pro |
02-09-2019, 05:04 PM | #211 |
| Re: New G6 build
Mounted.There you go boys and girls,it's that easy. Need some outdoor action pics when it warms up outside. Sent from my iPad using Tapatalk Pro |
New G6 build - Similar Threads | ||||
scx10 G6 2.2 Wroncho/Wrangler Build (AKA The Sleeping On The Couch Build) | Irishchamp | 2.2 Scale Rigs | 45 | 10-09-2014 10:26 PM |
Jeep scaler build and comp micro crawler build | droopmodmrc | Losi Micro-Rock Crawler | 1 | 12-25-2012 12:34 PM |
~53 Willys 2010 Comp Rig Build~ RC4WD MOA Worminator Build~ | 53 willys | General Crawlers | 108 | 11-28-2011 12:42 AM |
RcBros LCC Build, Hi-Res pics & More Build!! | RcBro | Team Losi Comp Crawler | 30 | 06-03-2009 07:26 PM |
