11-15-2014, 02:11 PM | #21 |
Rock Crawler Join Date: Mar 2006 Location: Dogpatch
| Re: New G6 build |
11-15-2014, 02:29 PM | #22 |
| Re: New G6 build |
12-21-2014, 02:13 PM | #23 |
| Re: New G6 build
[IMG][/IMG]Here is g6 build number two.Waiting on some Green Slime to build the shocks then I can continue.
12-23-2014, 04:42 PM | #24 |
| Re: New G6 build |
12-25-2014, 10:56 AM | #25 |
| Re: New G6 build
New parts for Christmas! Axial beadlocks with GearHead rings STRC alum front & rear end parts. RC4WD Compass 1.9 tires. [IMG][/IMG] [IMG][/IMG] [IMG] [IMG][/IMG][/IMG] Last edited by RiderZ; 12-25-2014 at 10:59 AM. |
12-25-2014, 11:51 AM | #26 |
| Re: New G6 build
Going to start building shocks for my other G6.Then I can get the front/rear duffs mounted.These Compass tires are a little bigger than the Treps
12-25-2014, 05:57 PM | #27 |
| Re: New G6 build |
12-26-2014, 01:38 PM | #28 |
| Re: New G6 build
Had the yellow G6 outside today.Running around the yard & through the landscaping.Really liking the Compass tires.I feel like I'm talking to myself here!!!
12-26-2014, 09:19 PM | #29 |
I wanna be Dave Join Date: Jun 2004 Location: San Jose
| Re: New G6 build
Have a part # for the exhaust?
12-26-2014, 09:26 PM | #30 |
Newbie Join Date: Dec 2009 Location: adell
| Re: New G6 build
They both look great like the gearhead rings |
12-30-2014, 07:07 PM | #31 |
| Re: New G6 build |
12-30-2014, 07:51 PM | #32 | |
Quarry Creeper Join Date: Feb 2006 Location: Muskegon
| Re: New G6 build Quote:
Have you had the compass tires in any mud yet? Are they wider and taller? I'm looking for something a little more appropriate for trailing on my Deadbolt | |
12-30-2014, 08:02 PM | #33 |
| Re: New G6 build
No mud with these tires yet.It was only 18 degrees today.No mud to be had.Probably won't do mud with these trucks as the esc's are not protected.The Compass tires are taller & wider than the stock Treps.
12-31-2014, 12:03 PM | #34 |
| Re: New G6 build |
01-04-2015, 01:04 PM | #35 |
| Re: New G6 build |
01-07-2015, 11:41 AM | #36 |
| Re: New G6 build |
01-07-2015, 02:26 PM | #37 |
Quarry Creeper Join Date: Jun 2014 Location: Seattle-ish
| Re: New G6 build
I need to work on my battery relocation next. I like how you did yours. How hard was it to move everything around?
01-07-2015, 02:57 PM | #38 |
| Re: New G6 build
Not hard at all.With my battery plate I lined it up at the front of the chassis.Then drilled two holes just inside & outside of each frame rail.Then ran a plastic zip tie around each frame rail to secure it to the chassis.Simple.The rx box just uses two screws to mount to the rear frame cross member.
01-07-2015, 09:22 PM | #39 |
Newbie Join Date: Jan 2015 Location: seattle
| Re: New G6 build
Awesome! I'm working on mine right now. I'll drill the holes and try that.
01-08-2015, 07:02 AM | #40 |
| Re: New G6 build
Awesome thanks! I tried a couple things and found a way to do it. It's not permanent yet until I run it a few times and see how it does
New G6 build - Similar Threads | ||||
scx10 G6 2.2 Wroncho/Wrangler Build (AKA The Sleeping On The Couch Build) | Irishchamp | 2.2 Scale Rigs | 45 | 10-09-2014 10:26 PM |
Jeep scaler build and comp micro crawler build | droopmodmrc | Losi Micro-Rock Crawler | 1 | 12-25-2012 12:34 PM |
~53 Willys 2010 Comp Rig Build~ RC4WD MOA Worminator Build~ | 53 willys | General Crawlers | 108 | 11-28-2011 12:42 AM |
RcBros LCC Build, Hi-Res pics & More Build!! | RcBro | Team Losi Comp Crawler | 30 | 06-03-2009 07:26 PM |
