Thread: Dingo to Bug - First SCX10 build
Old 07-30-2016, 06:44 AM   #41
Default Re: Dingo to Bug - First SCX10 build
Chris generis used a Bondic pen to fill holes in lexan if you still need to. I got one but haven't played with it yet.
Sent from my XT1585 using Tapatalk
Jeepy84 is offline   Reply With Quote
Old 07-30-2016, 09:03 AM   #42
Cool thanks. I saw one yesterday and was wondering what it was good for.
Tossedman is offline   Reply With Quote
Old 08-12-2016, 09:59 PM   #43
Put some new wheels and tires on the bug. 2.2 Vanquish SLWs and 1.9 Pro-Line K02 tires stretched over them. Can't see it here but I also patched the holes in the hood using a Bondic pen. We'll see how it holds out.
Old 08-22-2016, 05:27 PM   #44
Finally got around to doing some more work on the bug. Tried my hand at a bit of styrene work and built a cage around the engine. Been meaning to do this for quite a while now. All it needs is a bit of flat black paint.
Old 08-22-2016, 09:23 PM   #45
And here it is with a shot of Krylon flat black paint.
Old 08-23-2016, 02:42 PM   #46
Got rid of the Vanquish SLW wheels and put the Axial plastic rims back on. I like the look of black on brown. The SLWs had a bit too much bling for this thing. I'm also liking how the paint is chipping off here and there and showing the darker colour underneath.
Old 08-23-2016, 08:24 PM   #47
Gives it character
Engine guard turned out good, but gotta lose the body mounts through the rear window. Any chance of using magnets or Velcro?
Mike Flea is offline   Reply With Quote
Old 08-23-2016, 08:47 PM   #48
Yeah I'm trying to figure out a good way to get rid of those body mounts. Velcro would work if I hadn't trimmed the frame rails. Maybe I otta get me another set.
Old 08-25-2016, 06:27 PM   #49
OK, bought some new rails today as well as some 1, 2 and 3 mm Sintra to play around with to make an interior of some kind. Should be able to use magnets to hold on the body on in the rear instead of those ugly body posts. Not sure what I'll do about the holes. Probably just let them be.
Old 08-26-2016, 02:19 PM   #50
Well, it turns out that I didn't need new rails, just needed to think a bit. Added some velcro to the back end of the frame brace and the inside of the body. Holds like a charm. I'll take the rails back to the LHS and save that money for an SCX10 II kit.
Thanks for the idea Mike Flea!
Old 08-26-2016, 04:32 PM   #51
Look! No more body posts! Should'a thought of this years ago.
Sits nice and low as well.
Old 08-26-2016, 06:52 PM   #52
Glad it worked out, looks like a 1:1 now
Old 08-26-2016, 06:57 PM   #53
Yeah, it's getting there. Working on the dash board right now. I'm going to try to cut 1mm Sintra on my wife's Silhouette Cameo cutter. Gotta make a cut file first.
Old 08-26-2016, 08:52 PM   #54
Dude, this thing is inspirational! Love it!
2JSC is offline   Reply With Quote
Old 08-26-2016, 09:01 PM   #55
Thanks man. It's slowly coming together.
Old 08-26-2016, 09:10 PM   #56
Are you using it in C1 or C2?
Old 08-26-2016, 09:12 PM   #57
Nothing yet. But most likely C2. Gotta add more stuff to if though.
Old 08-28-2016, 06:14 PM   #58
Spent the day messing around with a dashboard. Spent a lot of time on something that won't really be seen but what the heck eh. Here's the dash I'm looking to emulate.
Used the Silhouette Cameo to score some 1mm Sintra to the shape of the dash.
It's too thick to cut with this machine but it gave me a line to finish with a sharp knife. Then I painted it flat black.
Then I used to cutter to cut some white vinyl with the dash details. Since most VW dash boards back in the day were the same colour as the car I painted the vinyl with some flat brown. The vinyl is self stick. Cool stuff!
Them I printed out a picture of a speedometer sized to fit the dash. A bit of glue and Bob's your uncle! Using an axial steering wheel as well. Just started painting it white.
Now to figure out how to mount it in the lexan bug body. Think I need some more shoe goo. Mine seems to have turned into a hard blob. Gotta make some knobs as well.
Old 08-28-2016, 08:08 PM   #59
That's too cool.
Brake Weight is offline   Reply With Quote
Old 08-29-2016, 09:11 PM   #60
Thanks man. It's been a learning experience but fun all the way.
Dingo to Bug - First SCX10 build - Similar Threads
LeeSc10's Scx10 Dingo build Ballistic17 Axial SCX-10 32 03-10-2014 10:16 PM
SCX10 Baja Bug Build lodger Axial SCX-10 16 09-01-2013 05:36 PM
Axial SCX10 Dingo Build DrMend Axial SCX-10 21 05-14-2013 11:34 PM
Famous112's SCX10 Dingo build! Famous112 Axial SCX-10 27 05-09-2013 10:32 PM
SCX10 Dingo Build Questions evankitz Axial SCX-10 8 03-22-2012 08:03 AM
