Thread: High Clearance Links
Old 02-17-2015, 09:05 PM   #1
Default High Clearance Links
Anybody know where to get high clearance links for a 12.3" wheelbase? need a set to compare some things on.
Thanks in advance.
jtessmer88 is offline   Reply With Quote
Old 02-17-2015, 09:10 PM   #2
"GOD SPEED"
Default Re: High Clearance Links
Blue monkey makes a nice set with panhard and servo mount.
nerby149 is offline   Reply With Quote
Old 02-17-2015, 09:17 PM   #3
I joined the Band!
Suspension and Steering, Blue Monkey RC
Eric0424 is offline   Reply With Quote
Old 02-17-2015, 09:32 PM   #4
Axial SCX10 Heavy Duty High CLEARANCE Aluminum 4 Link Kit | eBay
Haven't used these personally, but looks like a good set for decent price.
snicklefritz is offline   Reply With Quote
Old 02-17-2015, 09:48 PM   #5
White knuckle rc makes a good set imo^^^
Sent from the clouds
Captainkickass is offline   Reply With Quote
Old 02-18-2015, 12:59 AM   #6
Does it increase performance? There is still a low clearance drive shaft.
nersik is offline   Reply With Quote
Old 02-18-2015, 07:33 AM   #7
When trying to breakover a obstacle with straight links the first thing to hit is the link, it slows you down,loosing your momentum in the process. With high clearance links, the driveshaft may hit first, but because it is spinning it does one of two things, or both. It slides up the obstacle, and or kicks the rear axle over the direction it is spinning until the tire contacts the obstacle.
Now in the 1:1 world you do not want the drive shaft pounding on rocks, so you will find straight links on most trucks. Our Rc trucks have such heavy duty parts it is not a big deal to use the driveshaft as another traction aid.
lonleycreeper is online now   Reply With Quote
High Clearance Links - Similar Threads
best high clearance links? 1natehundred Axial XR10 8 02-20-2013 10:34 PM
High clearance links Squirrels Axial XR10 3 08-01-2011 01:28 AM
High clearance links... COME GET EM! Erik D_lux Team Losi Comp Crawler 53 12-28-2010 02:53 PM
High Clearance links Philster123 HPI Wheely King 0 08-24-2010 02:56 PM
high clearance links Mac10 General Crawlers 16 08-21-2007 11:05 AM
