02-18-2015, 10:15 AM | #1 |
Newbie Join Date: Aug 2014 Location: ankara
| drive shaft shaking
Gearbox causes ehis shaking. However it is not fixed after my rebuild. Do you hve any idea how can i fix it. Does it cause any problem like that? https://www.youtube.com/watch?v=vW_S...ature=youtu.be |
02-18-2015, 10:40 AM | #2 |
RCC Addict Join Date: Jul 2012 Location: Oreganastan
| Re: drive shaft shaking |
02-18-2015, 02:44 PM | #3 |
yes, they are lined up. but i still have the problem
02-18-2015, 04:36 PM | #4 |
Pebble Pounder Join Date: Feb 2014 Location: NH
Okay, the outputs are lined up... but are the pins on each end of the driveshaft lined up? Has this recently started? Has it worked properly before? Have you done anything that may have changed the drive-shaft angle, like changing the links? When you say you rebuilt the "gearbox", is that the center transmission, or the differential gears? |
02-18-2015, 05:05 PM | #5 |
I joined the Band! Join Date: Dec 2014 Location: Earth
Pull the drivehaft loose from the transmission and see if it's the output or the driveshaft. Looks like the coupler on the drivehshaft may be drilled off center or something (coupler, U-joint, shaft, output) on the transmission end of the driveshaft may be bent/warped.
02-24-2015, 10:25 AM | #6 |
i disconnect the driveshafts and tested it. transmission links are shaking and that makes driveshaft shake. do you have any suggestion how can i fix it? do i open the transmission and check gears? |
02-24-2015, 10:57 AM | #7 |
Yeah, sounds like you need to open up the transmission and check the bearings, gears and outdrives.
02-24-2015, 02:59 PM | #8 |
the outdrives have probably come loose from the bottom gear, its a fairly common occurrence on some rigs..hopefully you have caught it in time before it damages anything.
02-26-2015, 02:19 AM | #9 |
after rebuilding and oiling my transmission it is now better. however there is a small shaking...
02-26-2015, 05:00 AM | #10 |
You'll have a little bit of shake even if everything is okay. The bearings have some minor slop in them, the bottom gear isn't exactly centered in the outdrives and the outdrives are not exactly centered to each other. There's a little bit of shake/wobble in mine and I know everything is in great condition inside.
03-10-2015, 06:12 PM | #11 |
Newbie Join Date: Feb 2015 Location: BC
Just ripped apart my tranny last night wonder why my axle was rubbing on my slipper cover, pinned it down to the outdone shafts wobbling...decided to swap axles and now the front drives haft wobbles and the rear doesnt....must have bent the stock WB8 HD shaft??
drive shaft shaking - Similar Threads | ||||
drive shaft help | tlsrcs | Newbie General | 2 | 09-29-2012 11:18 PM |
best way to join a rwvo drive shaft to the output shaft on the axle | TRAV | Kyosho Crawlers | 12 | 01-29-2012 07:37 PM |
Drive shaft help.. | Crawler80 | Losi Mini-Rock Crawler | 3 | 01-09-2010 02:51 PM |
***MIP C-Drive Drive shaft for the AX10...GIVEAWAY*** | Rockpiledriver | RCP Crawlers | 153 | 07-01-2008 11:18 AM |
