04-03-2015, 02:51 AM | #1 |
Newbie Join Date: Apr 2015 Location: Australia
| Scx10 wider rear axles
I am in the process of doing the xr10 diff mods to my honcho. I have the front sorted but cannot find anywhere that sells the xr10 rear axles. Is there any alternatives or do I have to use the extended hubs?
04-03-2015, 08:43 AM | #2 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
| Re: Scx10 wider rear axles
use a larger hub in the rear to get the axle length close to even if you wan that...the XR mod is normally done to just the front axle
04-03-2015, 09:19 AM | #3 |
I'm not sure which axle shaft's go with it.. But, wraith lockouts would give you a wider rear on a scx housing. Maybe you have to cut them to fit? But you will with the XR mod, unless your doing the full width mod. |
04-03-2015, 09:21 AM | #4 |
Pebble Pounder Join Date: Feb 2007 Location: Ca 530
Vanquish just realeased xr10 width front and rear currie axle xr10 width tubes and rear shafts New Releases - Vanquish Products |
Scx10 wider rear axles - Similar Threads | ||||
Help make rear axle wider. | téosrc | Axial Yeti | 3 | 01-13-2015 05:26 AM |
Wider Axles for SCX10 | rspicko | Axial SCX-10 | 10 | 08-22-2013 08:05 AM |
