04-27-2015, 08:11 PM | #1 |
Rock Crawler Join Date: Aug 2011 Location: SB
| New SCX10 Honcho
Hello, Hear is my new Honcho. I am keeping this a inexpensive build, for now. Hear is what I ordered today Axial Aluminum Wheelbase Links Set 12.3 (313mm) King Off-Road Scale Piggyback Shocks w/Faux Reservoir (100mm Traxxas Hex Wheel Hub 2.5x12mm Fr Rustler/Stampede/Slash (2) VANQUISH Axial SCX10 stage 1 kit Blue Hot Racing Axial SCX10 AX10 Wraith hard steel center gears set Junfac Hardened Universal Shaft for Axial Honcho. I had a question for the stage one kit it states Will require new tie rod and drag link, due to this being a high steer Zero Ackerman Knuckle. Will the tie rod and drag link from the Axial Aluminum Wheelbase Links Set work? or what do I need? Parts will be hear Wednesday Thanks |
04-27-2015, 08:23 PM | #2 |
| Re: New SCX10 Honcho
Hope you don't mind that I moved this out of the Yeti forum to its proper spot.
04-27-2015, 08:31 PM | #3 |
Thanks, My bad
04-27-2015, 09:32 PM | #4 |
Do I need the Vanquish Products Titanium "Currie" Drag Link & Tie Rod Set?? I did order the Vanquish Titanium "Currie" Drag Link & Tie Rod Set Last edited by desertdude; 04-27-2015 at 09:59 PM. |
04-27-2015, 09:52 PM | #5 |
Newbie Join Date: Oct 2014 Location: Springfield
The currie one won't work for you, I'd say the axial upgrade one should work for you just might have to play with different rod ends to get the perfect length
04-27-2015, 10:51 PM | #6 |
Bummer lost that $22 gamble. I already ordered the "Currie" Drag Link & Tie Rod Set . O well Im sure I will use them down the line I saw a video on you tube from The RCNetwork , he claimed it was pretty much a must. https://youtu.be/tKmZ2_UUhsE Last edited by desertdude; 04-27-2015 at 10:54 PM. |
04-28-2015, 06:52 AM | #7 |
Pebble Pounder Join Date: Jan 2014 Location: Chester, WV
Vanquish makes a steering and drag link that will work with the stock axles, with the stage one kit.
04-28-2015, 08:26 AM | #8 |
yes the Vanquish Products Titanium "Currie" Drag Link & Tie Rod Set correct?
04-28-2015, 08:58 AM | #9 |
RCC Addict Join Date: Aug 2012 Location: Philippines
The Currie link set will work with the VP 8° high steer knuckles... just get those! Then you'll probably have to run wideners to make the wheels clear. But you could just get VP wheels and run the right width SLW hubs.... Yeah VP, I know your tricks... |
04-28-2015, 11:15 AM | #10 |
i was on the vanquish site trying to find the item number that you need but i cant find it sometimes i dont feel they have the most user friendly site...i would just call them up and ask...like mentioned above you will need to use the stage one kit knuckles....
04-28-2015, 02:57 PM | #11 |
Thanks guys, I have both now, and on vanquish's website it says •Requires Currie/SCX 8 Degree Knuckles Titanium Tie Rod/Drag Link VPS06739, looked up the number and bingo, I got a set of Knuckle Bushings when I ordered just incase. I got a few sets of Traxxas Hex Wheel Hub 2.5x12mm Fr Rustler/Stampede/Slash. If they don't give me the clearance I will farm the Junfac Wheel Widener (Offset: +13mm) off my Wraith, I will just have to drill out the wheels to 5mm. Wheels are Axials old school 1.9 8 hole beadlocks. Will see what works I will post pictures over the weekend |
04-28-2015, 04:21 PM | #12 |
Pebble Pounder Join Date: Apr 2013 Location: Penn Yan
Are the knuckles VP 8 degrees?
04-28-2015, 07:12 PM | #13 |
Yes
04-28-2015, 07:38 PM | #14 |
| Re: New SCX10 Honcho these will work with the 8 degree knuckles and chassy mount servo. Currie/SCX 8 Degree Titanium Tie Rod/Drag Link - Vanquish Products |
04-28-2015, 07:42 PM | #15 |
Quarry Creeper Join Date: Apr 2015 Location: Georgia
Will the Panhard kit from vp with all the links work with the stage 1 kit
04-28-2015, 08:46 PM | #16 |
If its the one for the stock axles it will
04-28-2015, 09:08 PM | #17 |
Bc I just ordered my scx10 kit and seen the stage 1 kit requires the currie drag link and steering link and I was gonna order the pan hard kit with the lower and upper axle links
04-29-2015, 05:38 AM | #18 |
the one link kit has everything you need (links, CMS, and pan hard), its like 120.00 but worth every penny, you could always sell the other stuff you ordered on here...
05-08-2015, 06:30 PM | #19 |
Just about finished
05-08-2015, 07:32 PM | #20 |
Pebble Pounder Join Date: Jan 2015 Location: South Central PA
| New SCX10 Honcho
Is that a skid plate in the last picture? It hangs down really low and is going to get hung up on all kinds of things. Other than that looks like a nice build.
New SCX10 Honcho - Similar Threads | ||||
RC4WD Trail finder 2 Axial SCX10 Honcho Rusty Bug honcho wraith at Durian Loop Trail | boolean21 | Scale Videos! | 0 | 04-06-2014 09:08 AM |
RC4WD Trail finder 2 Axial SCX10 Honcho Rusty Bug honcho wraith at Durian Loop Trail | boolean21 | Scale Videos! | 0 | 03-24-2014 05:02 AM |
New guy, SCX10 Honcho RTR, a few questions about my Honcho | dan188 | Axial SCX-10 | 2 | 10-04-2013 09:43 AM |
Will SCX10 Honcho Kit Parts Fit on Older SCX10? | alexchen86 | 1.9 Scale Rigs | 4 | 12-23-2009 03:56 PM |
