06-29-2015, 09:29 PM | #1 |
Pebble Pounder Join Date: Dec 2014 Location: bryant
| question on scx10 front axle
Hi guys. I put the hot racing aluminum knuckle and C hub on my scx10 and now after a couple trail runs the screw comes lose from the C hub. Sometimes the screw will almost come out. Any suggestions?
06-29-2015, 09:31 PM | #2 |
Quarry Creeper Join Date: May 2012 Location: Italy
| Re: question on scx10 front axle
Maybe you stripped the thread into the axle...you may try with some glue...Or add the beef tubes!
06-29-2015, 09:49 PM | #3 |
I don't think they stripped out. I did lock tite them. What is a beef tube?
06-29-2015, 09:52 PM | #4 |
| Re: question on scx10 front axle |
06-29-2015, 09:52 PM | #5 |
loctite should hold them in... did you replace the stock screws with machine screws?
06-29-2015, 09:53 PM | #6 |
06-29-2015, 10:21 PM | #7 |
I replaced the screw that came with the C hub. They where not a fine thread if that is what you mean.
06-29-2015, 10:22 PM | #8 | |
| Re: question on scx10 front axle Quote: | |
06-29-2015, 10:27 PM | #9 |
How hard do you guys think it would be to make one out if a scrap tube?
06-29-2015, 11:14 PM | #10 | |
If you know the required specifications, have some experience with tooling and already have the necessary tools/materials. ^ If you're not confident in your ability or lack the proper tools... then IMO yer better off buying them already made. Accuracy will be critical to insure that the grub screw's drilled/threaded holes line up properly. I own all the proper tools... and still chose to buy rather then fabricate my own. | |
06-29-2015, 11:16 PM | #11 |
I got tools to make stuff like this. So I mite have a go at it thanks guys for the help.
question on scx10 front axle - Similar Threads | ||||
Narrowing front Wraith Axle for front of scx10 | rusty577 | Axial SCX-10 | 12 | 02-02-2013 10:30 PM |
Front axle question... | Ghostrider304 | Axial SCX-10 | 3 | 11-28-2012 08:30 PM |
Front axle question... | Ghostrider304 | Axial AX-10 Scorpion | 2 | 11-27-2012 06:03 PM |
