07-29-2015, 08:39 PM | #1 |
Pebble Pounder Join Date: Jul 2009 Location: Loretto
| School Boy's SCX10 Fleet Since I now have enough rigs to run a small feet of crawlers, pun intended, I decided to combine each of there progress from now on out into one thread. For now im just going to put up a couple pics and info later! Last edited by school boy; 07-30-2015 at 09:14 PM. |
07-30-2015, 04:03 PM | #2 |
| Re: School Boy's SCX10 Fleet Since this was my first scx truck, bought it the first year it was released, I only feel that its the first on the chopping block. This was a kit truck and sports the original aluminum 3 link front and rear. The add ons were an: RC4WD 35T motor Novak Rooster esc 7 cell 5000mah dedicated battery relocated Traxxas 2075 servo and Radio RC4WD 1.9 Mud Bashers on Axial beadlocks with derlin rings RC4WD knuckles Hot Racing chubs 100mm cheapo aluminum shocks Custom steel bumpers Custom F100 body 20t pinion/87t spur Heres the build thread:Rusty Ford F100 SCX10 Last edited by school boy; 07-30-2015 at 04:42 PM. |
07-30-2015, 04:12 PM | #3 |
| Re: School Boy's SCX10 Fleet The Deadbolt RTR is the newest, just got it 2 days ago. I thought I wanted a rtr model so I could drop batteries and go. Well not even a full battery in, the front steering arm is weakened to a point it bends under very little pressure and one of the rear lower links is so weak that if I gun it on gritted concrete, the tire rubs the rock slider. So I guess new metal links are on order soon! |
07-30-2015, 04:41 PM | #4 |
| Re: School Boy's SCX10 Fleet Well since I have several wheel/tire set laying around, I leaning toward changing the stock Treps for something else. The first pics shows height difference. The first set is the Imex J-hawgs on a set of 2.2 CAD beadlocks. 120mm tall The 2nd set are the RC4Wd Dick Cepek 1.9 Mud Country's on weighted Axial 1.9 wheels. 100mm tall. The 3rd are the Axial 1.9 Ripsaws on RPM 2.2 narrow crawler wide-offset wheels. 109mm tall. For reference, the Treps are 117mm tall. |
07-30-2015, 09:20 PM | #5 |
| Re: School Boy's SCX10 Fleet |
08-12-2015, 08:24 PM | #6 |
08-15-2015, 09:53 AM | #7 |
| Re: School Boy's SCX10 Fleet So I went out today for the Deadbolt's first true run with its upgrades. Performed great! Well.... until I got cocky and started jumping it off a 3 ft ledge! My dilemma.... well since I'm confined to my wheelchair, I didn't want to make the 20 minute round trip to travel around the shop builds to turn it over So off Rusty goes to rescue! |
08-17-2015, 02:34 PM | #8 |
| Re: School Boy's SCX10 Fleet So on to the next introduction of my yet to be completed H1 Tow Rig. Seems this thing gets worked on very little and sat in the corner a lot It sports an RC4WD chassis RC4WD R2 trans with Axial 20 turn Axial AE2 esc Traxxas 3 channel radio set up for winch Axial axles, stock RC4WD Double Trouble 2 wheels/Bogger tires Custom bobbed and doved H1 body And trying to build a tow boom lol Track star 1/8 scale servo Metal drive shafts |
08-19-2015, 07:54 PM | #9 |
| Re: School Boy's SCX10 Fleet Ok, a little teaser! Im not sure on which rig these will go on but bought these wheels/tires cheap just to use the tires, just a few minutes on them and they weren't glued. The made to order beadlocks are on order. I tested the tires on my deadbolt and deffently better than the treps for me! But..... I repeatedly popped the front tire beads off since they weren't glued. Sooo, I decided t throw on the weighted DC's that come in on a roller I bought. Even though they are shorter, the extra weight deffently helped out and worked better than the treps. |
08-19-2015, 08:07 PM | #10 |
I'm learning real quick that weight in the front wheels makes a noticeable difference. That H1 is badass.
08-19-2015, 08:46 PM | #11 |
| Re: School Boy's SCX10 Fleet It's been a long time project, I'm hoping to finish it up to be able to be a recovery/tow rig sometime next month. |
08-19-2015, 11:07 PM | #12 |
I'm sure I'm not the only one who'd love to see a video of it flexing out over some rocks and rough stuff. Finish that bad boy.
08-20-2015, 02:56 AM | #13 |
Rock Stacker Join Date: May 2015 Location: Hong Kong
08-20-2015, 09:41 AM | #14 |
| Re: School Boy's SCX10 Fleet Here's the original build thread , its been a while! my first build thread, H1 Tow Rig Asia Tees, I believe the first set of duals on this rig were from you! |
08-21-2015, 04:15 PM | #15 |
08-23-2015, 02:17 PM | #16 |
| Re: School Boy's SCX10 Fleet Up next in introductions is my Dually Crawler. Truly only built this rig because I wanted to run my Double Trouble 3 wheels Stock SCX10 frame, axles and trans. Novak Rooster Crawler esc with RC4WD 27t motor Standard axial front links with custom longer rear links Hitech mg645 servo Double Trouble 3 wheels and RC4WD Mud Basher tires RC4WD rear honcho metal bed Custom honcho body Rear stock shocks relocated/front 100mm aluminum cheapo shocks Deadbolt front bump |
09-04-2015, 04:51 PM | #17 |
| Re: School Boy's SCX10 Fleet So done a little work on Rusty today. Wasn't getting full turning lock so I started adjusting and clearancing the links. First started by bending the steering link and adding a small spacer so the toe angle is correct. Moved the drag link to the lower hole on the servo arm. This gave me most of my turning radius back! |
09-08-2015, 07:58 PM | #18 |
09-09-2015, 08:53 PM | #19 |
09-10-2015, 08:23 PM | #20 |
School Boy's SCX10 Fleet - Similar Threads | ||||
School says deaf boy's name sign looks too much like a gun | jammin311 | Chit Chat | 23 | 08-29-2012 12:49 AM |
My boy's new FOFF | motocooney | Formula Offroad | 27 | 06-18-2012 04:22 AM |
The Boy's RS 10 | EL PHANTASMO | Redcat Crawlers | 7 | 12-28-2011 12:37 PM |
my two boy's and my x-trails | shrek | 2.2 Scale Rigs | 44 | 02-12-2009 05:57 PM |
line me up some rails boy's | sloppy | Non Crawler RC's | 7 | 04-28-2008 04:17 PM |
