08-18-2015, 09:36 AM | #1 |
Rock Stacker Join Date: Oct 2012 Location: GREEN ISLE MN
| Integy cage build. Paid but back ordered . |
08-18-2015, 09:38 AM | #2 |
| Re: Integy cage build. Integy's roller pic. |
08-18-2015, 01:46 PM | #3 |
Rock Crawler Join Date: Mar 2006 Location: Dogpatch
Looks fairly good for an Integy product.
08-18-2015, 05:37 PM | #4 |
Price tag a little over $100 figure get one in my hands and see what can be built on it.
08-18-2015, 06:28 PM | #5 |
I joined the Band! Join Date: Dec 2014 Location: Earth
| Re: Integy cage build. I keep bouncing between buying a pre-made cage and hacking it up to get what I want or just building one from scratch. That looks like it would be easy to remove or fab-in whatever you need and the rock sliders are a nice addition.
09-04-2015, 03:19 PM | #6 |
| Re: Integy cage build. So they sent me the wrong chassis! .It's the same price and the 1.9 chassis is still back ordered so i decided to keep it. |
09-04-2015, 03:21 PM | #7 |
So 1.9 Wraith it is.. Scx drivetrain |
09-04-2015, 03:26 PM | #8 |
| Re: Integy cage build. |
09-04-2015, 03:27 PM | #9 |
Rod end modded a set of losi 4" shocks for it.
09-05-2015, 05:31 PM | #10 |
| Re: Integy cage build. Axles prepped.. Waiting on upper link mounts and skid tho arrive. |
09-05-2015, 05:33 PM | #11 |
All traxxas rod ends Lunsford ti drag link Aluminium servo mounts. |
09-05-2015, 05:37 PM | #12 |
09-10-2015, 11:53 PM | #13 |
A local machinist by the name of Josh Abraham offered these nicely done aluminum cases up for sale that he has been machining up.. This case allows the stock spur gear cover to be utilized in a mirrored configuration. Here did the good job machining and everything seems smooth and super strong and the weight balance of the total package is much better then the plastic case. I installed a Robison racing 90t and brass 22T pinion for super quiet operation. Also received in the mail a EPIC 27T stock 'rebuildable bushing motor after I had bearings freeze in my jeep at a g6 recently and almost cost me a dnf . Also... Upper link mounts are almost here and got link making materials . should have a roller soon. |
09-10-2015, 11:53 PM | #14 |
09-10-2015, 11:58 PM | #15 |
09-11-2015, 05:00 AM | #16 |
I like your concept it will be interesting to see where this is going. Any weight reduction plan? The cage looks like it might be heavy, what does it weigh? Any time you can lose some weight any where above the axle line it directly effects the rigs capabilities.
09-11-2015, 07:11 AM | #17 |
Be careful with that motor you got. Stock motors come with cans locked at 24* of timing so they generate heat quickly compared to most crawler motors that run 0-6* of timing. I guess that is to be expected when they were designed to be run for 5 minutes at a time in a 3 lb buggy.
09-11-2015, 07:33 AM | #18 |
Excellent point. Kinda forgot they run such high timing on stock motors. Gonna play with gearing and hope for the best. I'm currently running the same armature in a trinity dirtinator can and it's seem to be doing really well. Love the high top operating rpm on 3s . |
09-12-2015, 05:33 PM | #19 |
| Re: Integy cage build. Skid plate came today and mounted up the transmission. |
09-14-2015, 08:26 PM | #20 |
| Re: Integy cage build. Piece by piece |
Integy cage build. - Similar Threads | ||||
integy scale 2.2 roll cage? | vxlblitz | Axial SCX-10 | 8 | 05-13-2012 02:52 PM |
Integy cage | jado6006 | Axial AX-10 Scorpion | 5 | 03-03-2011 05:54 PM |
2.2 integy roll cage | CREEPERBOB | Venom Creeper | 27 | 02-13-2011 11:24 AM |
integy 2.2 cage | ninetwofiveRC | Venom Creeper | 7 | 01-03-2011 03:42 PM |
Integy Cage | nightcrawler86 | Losi Mini-Rock Crawler | 8 | 05-19-2009 09:26 AM |
