08-30-2015, 11:12 AM | #1 |
Newbie Join Date: Aug 2015 Location: bowling green
| body fitting ?
Ordered a honcho a few weeks ago and now I've decided to order a falken jeep body for it. I was wondering what modifications need to be made to make it fit?
08-30-2015, 12:10 PM | #2 |
Rock Stacker Join Date: Aug 2015 Location: New Jersey
| Re: body fitting ?
In theory they are both scx10 bodies so there should be no modifications needed to make it fit the body posts. However there may be some trimming needed to clear the tires and side rails. Hope this helps
08-30-2015, 12:34 PM | #3 |
| Re: body fitting ?
Your honcho has a 12.3 inch wheel base while the falken G6 body is for a 12 inch wheel base. You will need to change the links out to get the 12 inch wheel base. You can find the lengths you need from the 12 inch wheel base kit. http://docs.axialracing.com/instruct...(305mm)_WB.pdf Other options: Axial SCX G6 Titanium 8pc. Link Kit 12.00 WB - Vanquish Products |
08-30-2015, 02:17 PM | #4 |
| Re: body fitting ?
thanks for the help guys. So without the link kit will it not work at all, or just not be very functional?
08-30-2015, 07:10 PM | #5 | |
| Re: body fitting ? Quote:
You could probably make it work by trimming the body to make it fit. You are going to have make the call of cutting up the body you just paid $$$$$ for or make/buy links that will give the proper wheel base for the body. | |
body fitting ? - Similar Threads | ||||
Fitting a Toyota body? | Bluebox | Axial Wraith | 2 | 11-13-2013 11:58 AM |
Fitting the Cherokee body on the 12.3" scx10 | Dustytrac | Newbie General | 3 | 03-31-2011 08:50 AM |
Fitting a body!!! HELP | Lexar | Paint and Body | 2 | 12-07-2010 07:52 AM |
Fitting 1/10 body on TLT | infernox | Newbie General | 2 | 03-14-2008 12:19 AM |
Body fitting tubers | a69baldone | General Crawlers | 6 | 12-11-2007 03:22 PM |
