Thread: Scx10 rear axle not turning smoothly upon assembly
Old 09-02-2015, 01:13 AM   #1
Default Scx10 rear axle not turning smoothly upon assembly
Hi folks,
Newbie here needing a little help.
As the title states, my rear axle is not turning smoothly when i turn it using my fingers. I checked inside to see if there was anything impeding it but i dont see anything that could. If disassembled it turns smoothly but when i close the housing for it that's when it happens. Any ideas?
Sorry for the newbie question. I tried searching for a fix but just couldn't find one.
Andy22 is offline   Reply With Quote
Old 09-02-2015, 03:46 AM   #2
Default Re: Scx10 rear axle not turning smoothly upon assembly
Make sure pinion bearing is seated.Pretty normal.The more you run it smoother it will get.
RiderZ is offline   Reply With Quote
Old 09-03-2015, 12:16 AM   #3
I had this problem, turned out to be the axles. I tried pinion shims, lube they wern't smooth unless I took it apart. I replaced axles w/ STRC and then they were perfect. Rolling the axle on a drill press showed one had a slight curve to it.
FloridaCrawler is offline   Reply With Quote
Old 09-03-2015, 01:25 AM   #4
The pinion yoke on the drive shaft
actually pulls the pinion shaft outward slightly
when it is attached and pinned.
The pinion yoke seats on the external bearing
or is very close to doing so.
so... pull the pinion shaft outwards with slight tension
when turning the pinion by hand.
it should be smoother...
and in time... will smooth up even more.
TacoCrawler is offline   Reply With Quote
Old 09-03-2015, 02:35 AM   #5
Thank you. The pinion bearing might have been the culprit. I took everything apart and reassembled it, made sure the bearing was flush as it can be. Now it is good to go.
Old 09-03-2015, 12:26 PM   #6
There ya go!
HDMM is offline   Reply With Quote
Scx10 rear axle not turning smoothly upon assembly - Similar Threads
VP Currie Rear Axle Assembly PrjktRedRubi Axial SCX-10 7 12-27-2012 06:20 PM
RC Axle Master Axial AX10/SCX10 Rear Straight Axle Kits LetsHandleit Axles, Trannys, T-case 41 06-24-2012 06:57 PM
CR-01 problem: wheels not turning smoothly. PumpkinPie Tamiya CR-01 2 01-01-2009 02:14 PM
