05-29-2016, 03:22 PM | #21 |
Pebble Pounder Join Date: May 2015 Location: The Rocky maintains
| Re: Austin's Slow SCX-10 build
Here is the body all cut out and ready for paint. Here's the honcho painted. Orange and gun metal. Chassis rails installed. All went together just as advertised. Its ready for stage 2 now. Going to be changing the axles out for the AR60's. Just need to gather the rest of the parts. Sent from my K01A using Tapatalk Last edited by austinc2099; 05-31-2016 at 11:20 PM. |
06-05-2016, 10:21 PM | #22 |
The axles for the new Wroncho build are coming along good. I have the dlux axle trusses installed and the link mounts installed. Way more to do to complete the conversion. Sent from my K01A using Tapatalk |
06-16-2016, 06:47 PM | #23 |
I got around to building the new links for the wroncho conversion. It now sits at 13.5 inch. The rear panhard mount is done. Sent from my K01A using Tapatalk Last edited by austinc2099; 06-17-2016 at 07:39 PM. |
06-19-2016, 07:49 PM | #24 |
What is a good way to run the rear drive shaft on a wroncho build? I am planning on running the extended and stubly outputs from super shafty and wraith WB drive shafts.
07-01-2016, 01:16 PM | #25 |
| Re: Austin's Slow SCX-10 build Turned Slow Wroncho build
I have been collecting parts for some time now. Here is a nice photo of the parts still in there bags. Sent from my K01A using Tapatalk |
07-01-2016, 01:23 PM | #26 |
Here is the front universals and knuckles laid out ready for install. Sent from my K01A using Tapatalk |
07-09-2016, 12:27 AM | #27 |
I finally finished my link set and set up an axle mounted servo with the Dlux fab upper link mount. It wasn't easy to figure out how to run the upper link and panhard bar without any interference with the servo and servo horn. Here are some pictures of it done without the wheels mounted. Sent from my K01A using Tapatalk |
07-11-2016, 11:44 PM | #28 |
I had a small problem with the modified knuckles. The outer bearing kept walking its way out of the bearing pocket. I drilled a small hole and added a screw for retaining the bearing in place since I didn't want to use adhesive for retaining it. We will see how it holds up. Sent from my K01A using Tapatalk |
09-10-2017, 07:11 PM | #29 |
Here is the 2.2 Wroncho done on the backyard rocks. Sent from my SM-G950U using Tapatalk Last edited by austinc2099; 09-10-2017 at 07:13 PM. |
09-10-2017, 11:20 PM | #30 |
Pebble Pounder Join Date: May 2014 Location: fernandina beach
Looks like you have gobs of articulation, just judging by the way you had to trim your body. Don't worry, mine looks the same way. I did the LCG frame and Currie Axle w/XR10 mod to mine....the fenders just had to go.
09-16-2017, 06:26 AM | #31 |
RCC Addict Join Date: Jun 2006 Location: Durham, NC, USA
you should get the toyota tacoma grill sticker sheet
09-23-2017, 10:37 PM | #32 |
Yes, the Toyota Tacoma is great truck. My 2.2 scx10 only has about the articulation of a beer can/soda can. It does great and crawls like a 2.2 sportsman. Sent from my SM-G950U using Tapatalk |
09-24-2017, 10:58 AM | #33 |
Newbie Join Date: Mar 2012 Location: Billings
That is one project that is on my hit list! Any snags to avoid if you were to do another? It is by far my favorite looking rig.
09-24-2017, 07:38 PM | #34 |
The rig went together great. The only thing that requires some fab skills is the rear panhard. A four link could be done in the rear as will as a chassis mounted servo, but the dlux servo mount/upper link mount provides a good place for the servo without bump steer. I am thinking of replacing the scx10 trans with the dlux cheeszeburger trans to help stop the torque twist. A pair of dlux knuckles would be interesting to see the performance increase. It already crawls great without any weights. Sent from my SM-G950U using Tapatalk Last edited by austinc2099; 03-23-2019 at 10:04 PM. |
09-09-2018, 02:58 PM | #35 |
Newbie Join Date: Oct 2017 Location: spain
Really nice set Up , with these back panhard do you eliminate the Torque twist ,right ?
10-25-2018, 09:38 PM | #36 |
It still has some torque twist, but not very much. I believe you want pan hard bars to be as long as possible and as close to parallel to the axle as possible. Sent from my SM-G950U using Tapatalk |
Austin's Slow SCX-10 build Turned Slow Wroncho build - Similar Threads | ||||
My slow low budget build 1.9 build | krono7s | 1.9 Scale Rigs | 7 | 08-28-2014 04:59 PM |
Go Slow YJ build | Oso787 | 1.9 Scale Rigs | 69 | 01-27-2012 09:31 AM |
Slow CC-01 Build | TruckerBrad | Tamiya XC/CC01 | 4 | 12-14-2010 07:22 PM |
slow 1.9 build | sudo | 1.9 Scale Rigs | 3 | 04-22-2007 05:51 PM |
