12-17-2015, 02:19 PM | #1 |
Quarry Creeper Join Date: May 2012 Location: Houston
| SSD Axles
Got my SSD axles in the mail and got them installed finally. These things are awesome. I also ordered the Vanquish stage one kit, lockers, and OD/UD gears. Also picked up the SSD bearing caps, brass tubes, and Aluminum truss. The Vanquish parts were a very tight fit. I had the remove some material off the rear axle to get the lockouts on. The chubs and knuckles went on tight, but I didn't have to cut anything. I also chose to stay with the axle mounted servo. I love how the panhard looks but I want to keep the flex I get now as well as keep as much weight down low as possible. I used 2x6mm stainless screws for the diff covers, which I think look pretty good, gives it a nice contrast. SSD killed it with these axles. The material is solid and the fit an finish is excellent. And their $25 a pair.....what??? Hopefully the weather holds out and I can do some trailing this weekend! |
12-17-2015, 02:58 PM | #2 |
| Re: SSD Axles
$25 per lol.
12-19-2015, 10:10 AM | #3 |
Rock Stacker Join Date: Feb 2015 Location: Grand Forks, ND
| Re: SSD Axles
Looks good, I've been eyeballing those axles for a while. Might have to skip the whole "wait until something breaks" and just grab a set.
SSD Axles - Similar Threads | ||||
1.55 Bronco, swb chassis, SSD D60 axles | Killa-Cotton | 1.5 Scale Rigs | 64 | 07-07-2017 09:23 AM |
SSD pro knuckles for SCX10 axles | joe.bielski | Axial AX-10 Scorpion | 5 | 10-20-2015 07:50 PM |
SSD knuckles rubbing axles | Justin82 | Axial Yeti | 19 | 01-30-2015 07:00 AM |
