05-12-2016, 04:51 PM | #1 |
Quarry Creeper Join Date: Mar 2016 Location: Moses Lake
| Problem with diver side alignment
It seems that my alignment is way off on the drivers side.....my trim is set at 0 on the transmitter, passenger side is nice and straight......but as you can see in the picture not so much the drivers side......any suggestions on what I should check to fix it? It's all stock axial wraith spawn axles. Thanks Sent From My Galaxy S6 Edge+ Last edited by sharkattack99; 05-12-2016 at 05:00 PM. |
05-12-2016, 06:26 PM | #2 |
Quarry Creeper Join Date: Feb 2016 Location: Australia
| Re: Problem with diver side alignment
Is the steering bar in the same hole on both sides. And are you sire its for an scx10.. It looks a lot longer then mine and that would throw one of them out. Edit: just re read and saw they are not stock axles. Sent from my SM-N910G using Tapatalk |
05-12-2016, 06:57 PM | #3 |
Yeah, there is only one hole for it to go into. I'm kind of stumped I want to say maybe the steering link is to long but it's for the wraith so it shouldn't be. Sent From My Galaxy S6 Edge+ |
05-12-2016, 07:58 PM | #4 |
Quarry Creeper Join Date: Dec 2015 Location: United States
The link is too long and with it being a one-piece link you'll have to bend it if you want to shorten it.
05-12-2016, 07:59 PM | #5 |
It is, like by 2-3mm
05-12-2016, 08:07 PM | #6 |
| Re: Problem with diver side alignment |
05-12-2016, 08:36 PM | #7 |
Ok after bending it little by little I got it much straighter and judging by how hard it was to bend it wasn't off cause of hitting a rock damn. ... lol. Thank goodness thanks guys my project overkill can move on lol. Sent From My Galaxy S6 Edge+ |
05-16-2016, 01:51 AM | #8 |
Quarry Creeper Join Date: May 2012 Location: Portland
Guess its too late to say this really.. but if you just trimmed your radio a little so both tires were toed out (angled outward) by the same amount.. you would get a little quicker turning and slightly tighter turning radius. HR links are known to be a little longer, so it wasn't anything you did. Last edited by rcwolf; 05-16-2016 at 01:57 AM. |
05-16-2016, 06:38 AM | #9 | |
| Re: Problem with diver side alignment Quote:
ah ok thats nice to know thanks, a little long on the suspension links would be fine but not the steering . | |
Problem with diver side alignment - Similar Threads | ||||
Steering/Alignment Problem After Install RPM Steering Knuckles? | Barzan724 | Newbie General | 2 | 01-21-2016 06:32 PM |
SCX10 Right Side Jump Problem | cyilmaz | Axial SCX-10 | 8 | 11-14-2014 05:52 PM |
dolphin comes to diver for help | vonclod | Chit Chat | 3 | 01-23-2013 10:39 PM |
Axial AX10/Tekin motor pinion alignment problem | cliffhanger007 | Axial AX-10 Scorpion | 11 | 11-14-2010 07:54 AM |
side winder drag brake problem | RockCrusha | Electronics | 10 | 03-30-2010 08:04 AM |
