05-21-2016, 03:16 AM | #1 |
Newbie Join Date: Dec 2014 Location: Chatham-Kent Ontario
| STRC CMS kit and aluminum upgrades in general
Hi everybody, been a lurker for a little while soaking up as much as I can. Today I have a question. I've been looking at some of the STRC aluminum upgrades particularly the CMS. Has anyone tried it, and what do they think about it? It looks alright and a pretty straight forward design, wondering if I should get this or the RC4WD one. Also how are the STRC parts in general on the SCX10? I have some on Traxxas Rustler and I they have worked pretty good for me. Heres a link to the CMS CNC Machined Aluminum Off-Axle Servo Mount/Panhard + STA30516 Steering Combo Kit for SCX10 (Black) |
05-21-2016, 07:16 AM | #2 |
Rock Crawler Join Date: May 2013 Location: Uniontown
| Re: STRC CMS kit and aluminum upgrades in general
The thing that bothered me about that kit when I was looking at CMS was the attachment to the knuckle spindle. No idea if it actually affects steering, just seemed like unnecessary stress on a vital component. Sent from my XT1585 using Tapatalk |
05-21-2016, 08:25 AM | #3 |
Okay, I see what you mean now. The RC4WD comes with its own panhard bar mount, I'm thinking thats the better option now. Anyone know if the RC4WD CMS panhard kit can be installed with a 4 link set-up in the front? |
05-22-2016, 09:40 AM | #4 |
RCC Addict Join Date: Feb 2008 Location: Tekin, ID
You don't need a pan hard if you 4-link, unless your links aren't triangulated.
05-22-2016, 10:26 AM | #5 |
RCC Addict Join Date: Oct 2014 Location: UK
| Re: STRC CMS kit and aluminum upgrades in general |
05-22-2016, 04:50 PM | #6 | |
Rock Stacker Join Date: Oct 2015 Location: Peoria, AZ
| Re: STRC CMS kit and aluminum upgrades in general Quote:
https://m.youtube.com/watch?v=yQaqEsVggUE | |
05-22-2016, 05:17 PM | #7 | |||
Quote: Quote:
Okay I watched the video, I don't really understand. I know what bump steer is and it's caused by a bad suspension angle, but why would a 4 link and panhard bar cause that. Last edited by wacmartin; 05-22-2016 at 05:32 PM. | |||
05-22-2016, 07:12 PM | #8 | |
Because, when you have your steering mounted on the chassis, you suspension travel has to be in an arc type of travel. Watch the video again. Now pay attention to the shocks when i press down. Watch how the shocks sway. If, i had 4 link, it will not allow the arc type of motion, thus causing bump steer. Imagine if you hold a pencil by the eraser. Now when the lead tip moves up and down. Notice the arc. The panhard rod is basically allowing the suspension to travel in the same arc as the steering. This, causing no bump steer. | |
05-22-2016, 09:12 PM | #9 |
Thank you, I understand that now. So basically if it's not in a smooth arc, when the suspension travels it's going to cause the wheels to pull or push and create bump steer. So with a CMS and a 4 link it's almost like the suspension is flailing around in sense, not crazily but any small amount well create bump steer. I'm going to go with some new aluminum upper links and a CMS panhard set up. Now to choose which one. BTW I really like how smooth your suspension travel is. I'm slightly hard of hearing and YouTube captions are terrible at best, so I missed what kind of shock mounts you have. If you don't mind telling me what they're please? Last edited by wacmartin; 05-22-2016 at 09:20 PM. |
05-22-2016, 09:48 PM | #10 | |
Yes, now you understand. A 4 link setup is very good at keeping the suspension traveling in the Y axis. Meaning straight up and down. And if you add a panhard rod to a 4 link, it will bind like crazy. Because, the panhard wants to arc as the suspension goes up and down. But, the 4 link won't let it arc. That is why, when you do a panhard rod. You have to remove one of the upper links to the axle. The panhard does 2 things.: 1. Keeps the axle from going from side to side. Also, Acts like the 4th link. 2. Allow for a smooth arc for the steering, thus preventing bump steer. Any adjustable shock mount will work. You can get both front and rears. http://www.ebay.com/itm/Aluminum-rea...8AAOSwZSFXJFAj These are the ones that I have. The reason for these, they also include an aluminum cross brace. Rear Shock mounts https://www.asiatees.com/display?Axi...d=117777&pid=1 Front Shock mounts https://www.asiatees.com/display?Axi...d=117776&pid=1 Last edited by Fastyz400; 05-22-2016 at 10:12 PM. | |
05-23-2016, 01:39 AM | #11 | |
05-23-2016, 09:52 AM | #12 | |
Sent from my XT1585 using Tapatalk | |
STRC CMS kit and aluminum upgrades in general - Similar Threads | ||||
STRC CMS Opinions | ShoNuff82 | Axial Wraith | 0 | 11-29-2014 05:11 PM |
STRC CMS Panhard kit | BallnM3 | Axial Wraith | 7 | 03-10-2014 08:08 AM |
General order of upgrades... | SgtVeXX | Newbie General | 9 | 02-19-2010 03:29 AM |
