![]() | #81 |
Rock Stacker Join Date: May 2016 Location: NY
![]() | #82 |
Quarry Creeper Join Date: Jan 2014 Location: Ukiah
Original SCX10 is a proven chassis the new one is a whole new ball of wax. Plus $350 for a kit is a bit pricey Sent from my iPhone using Tapatalk |
![]() | #83 |
Looking now for a 4channel radio...and the 3s battery kit that i should use...with the eletronics... Also a better rotor.. |
![]() | #84 |
I run Futaba 4PLS radio and I would recommend Holmes Hobbies for motor and ESC Sent from my iPhone using Tapatalk |
![]() | #85 |
Quarry Creeper Join Date: Mar 2016 Location: Moses Lake
![]() | #86 |
Found this one... chepear... did rread that AVC wil not hep me on crawlers, and also i can save some money...good one? Spektrum DX4C DSMR 4-Channel Radio w/ SR410 is there any 3s battery in special to get? will get everything today |
![]() | #87 |
Quarry Creeper Join Date: Mar 2016 Location: juneau
Go holmes hobbies or go home
![]() | #88 |
![]() | #89 | |
| ![]() Quote:
I will not be putting my model under water, but just in case, id like to have something prepared to everything... I will play in dirt, sand, street, mud... BATTERY thinking in a 3S LiPo, dunno wich one exactly, but gettin close to it! ROTOR Brushed more maintenace, but is better for my use? good torque, and lit bit of a speed also. My rig is gonna be a lit heavy, so a good torque will fit well i think saw in HolmesHobbies the TorquePro rotors...they look pretty good! ESC i gonna need the AE-5? id like to have a waterproof one, just in case... SERVOS I saw that i gonna need a strongest servos on my rig... What will control my leds/channels rig/radio? | |
![]() | #90 |
Get Holmes Hobbies TorqueMaster ESC and motor (40t, best of both worlds IMO). Servo with at least 250 oz/in torque. HiTech is a great brand Castle Creations 10a BEC for extra power to the servo. Castle Link so you can fine tune the ESC and adjust the BEC Sent from my iPhone using Tapatalk |
![]() | #91 | |
| ![]() Quote:
so, am i getting close? RADIO Spektrum DX4C DSMR 4-Channel Radio w/ SR410 BATTERY thinking in a 3S LiPo, dunno wich one exactly, but gettin close to it! ROTOR waterproof? Brushed TorqueMaster PRO550? 21T? by HolmesBobbies ESC waterproof? TorquePro ESC by HolmesBobbies has a bunch of it, wich one? SERVOS waterprrof? HV500 Servo by HolmesBobbies (is that to much?) | |
![]() | #92 |
| ![]() RADIO Spektrum DX4C DSMR 4-Channel Radio w/ SR410 BATTERY 2x 2.200 3S batteries (distribute the weight more even) Cant find the Y harness to connect both batteries... CASTLE LINK Castle Creations Castle Link Programming Kit BEC Castle Creations BEC 10A Switching Regulator CHARGER Any one in particular? |
![]() | #93 |
Newbie Join Date: Mar 2013 Location: Layton, UT
| ![]() https://www.amazon.com/Tenergy-TB6AC...=1&*entries*=0 This is the charger I use. It has held up pretty well over the two years I've had it, and has tons of capability. |
![]() | #94 |
This is the Y harness to the batteries, right?? ![]() Sent from my iPad using Tapatalk |
![]() | #95 | |
| ![]() Quote:
Thanks man!! Already in my cart! Dunno know wich brand of batteries to get. Everything else is decided! Sent from my iPad using Tapatalk | |
![]() | #96 |
Yes that would allow for two batteries. Just so you know, that splitter is wired in parallel, which will double your run time, as opposed to doubling power. Also, you will probably need to change the plug on your ESC and battery to fit that. Last I remember the AE-5 comes with a Molex/Tamiya plug, and that's a Deans/Ultra plug. As for batteries, I just use cheap Zippy lipos. That way, if it gets ruined it's a pretty minimal loss. Here is one that fits your description: http://www.hobbyking.com/hobbyking/s...dProduct=58891 Just so you know, most people I know just run one pack in their rig at a time, to keep weight low. But you can do whatever you want. Last edited by Derekuda; 06-01-2016 at 05:37 PM. |
![]() | #97 | |
| ![]() Quote:
For now im getting to make my rig run (correct me if im wrong..) RADIO Spektrum DX4C DSMR 4-Channel Radio w/ SR410 BATTERY 2x 2.200 3S batteries (what brand?) HARNESS "Y" Castle Creations Parallel Wire Harness (just like the picture above) CASTLE LINK Castle Creations Castle Link Programming Kit USB BEC Castle Creations BEC 10A Switching Regulator CHARGER Tenergy TB6AC 50W/5A AC/DC Dual Power Balancing Charger for NiMH/NiCD/Li-PO/Li-Fe/SLA VOLTAGE CHECKER Integy RC Hobby C23212 LiPo Voltage Checker + Warning Buzzer | |
![]() | #98 |
Sorry I noticed your other comment after I posted mine, then edited it trying to answer that one too, not expecting you to be so quick.
![]() | #99 | |
| ![]() Quote:
The SCX-10 Rubicon, cames with the AE-2 The connectros arent the same?? The battery must be 40C its better?? Sent from my iPad using Tapatalk Last edited by pcrescenti; 06-01-2016 at 05:54 PM. | |
![]() | #100 |
This yellow conector is the same as the "Y" harness that im buying?? ![]() Sent from my iPad using Tapatalk |
Tags |
jeep, replica, rubicon, wrangler |
SCX10 Dingo, Jeep Rubicon, Jeep Wrangler G6 hill climb rock bouncing | TAFF1969 | Scale Videos! | 0 | 07-16-2014 10:53 AM |
93 Jeep Wrangler Replica Build. | Beefalobart | 1.9 Scale Rigs | 18 | 06-25-2011 08:23 PM |
Crawlmaster exact dimensions | setecastronomy | Electronics | 3 | 02-18-2008 10:19 AM |
Exact size of the RR2 | Scattman | Chit Chat | 0 | 01-02-2007 07:35 PM |
