05-26-2016, 11:03 AM | #1 |
Pebble Pounder Join Date: Apr 2015 Location: Charleston
| SSD D60 axle question
Is the aluminum bearing caps needed? Sent from my iPhone using Tapatalk |
05-26-2016, 01:21 PM | #2 |
Pebble Pounder Join Date: Jun 2013 Location: Espoo, Finland
| Re: SSD D60 axle question
You mean those that hold the locker down in the axle? Just don't overtighten the plastic ones and you'll be good. Applies to both wraith and ssd D60 axles. |
05-26-2016, 03:09 PM | #3 |
Yea, those are what I'm talking about. Wasn't sure if it was a problem with them breaking or what not. I'm trying to plan how I'm gonna put them together. Don't plan on taking them apart unless something breaks. Sent from my iPhone using Tapatalk |
05-26-2016, 07:47 PM | #4 |
Quarry Creeper Join Date: Jan 2012 Location: winder, ga
Been running my ssd d60's for about 6 months. No problems to report on the stock bearing caps.
05-27-2016, 04:26 AM | #5 |
| Re: SSD D60 axle question |
05-28-2016, 02:11 PM | #6 |
Quarry Creeper Join Date: Dec 2010 Location: Hanford
I run the stock caps and diff covers. They're on a mud truck so I don't have to worry about the covers rubbing on rocks, but the caps seem to be fine in plastic. As said, don't over tighten then, just like plastic bead lock bolts.
05-28-2016, 02:13 PM | #7 |
I joined the Band! Join Date: Feb 2015 Location: On a rock
They ( the stock plastic ones ) are fine for the rear axle, In the comp scene a few of us have had the plastic ones give enough to let the gears slip.. After the aluminum bearing caps, and a shim to take up the slop from the housing, They work as intended, No slipping. |
SSD D60 axle question - Similar Threads | ||||
Ssd d60 housing | Bmxreeves | General Crawlers | 11 | 05-17-2016 01:18 PM |
New SSD Rear Axle Shafts for D60 Wide Axle (XR) | SSD | Axial SCX-10 | 0 | 05-17-2016 10:51 AM |
Offset SSD D60 axle | ctrwannabe | General Crawlers | 18 | 04-07-2016 08:58 PM |
