05-27-2016, 08:29 AM | #1 |
Pebble Pounder Join Date: Dec 2005 Location: lawrenceburg
| Kodiak Metal Works
Anyone have any experience with the lcg chassis on ebay by seller kodiak metal works?
05-27-2016, 01:47 PM | #2 |
Newbie Join Date: Mar 2016 Location: US
| Re: Kodiak Metal Works
I bought one... works great and looks great... tho I trimmed off the shock hoops to use ones I had... Sent from my Lenovo TAB 2 A10-70F using Tapatalk |
05-27-2016, 02:12 PM | #3 |
RCC Addict Join Date: May 2015 Location: Price Twp.
Doing a bronco build (in 1.9 section) on one right now. I am happy with the fit and finish of it. Only thing that needs to be done, is you have to remove the tabs off the skid if you use the stock one. For stock bumpers I had to do some shaving for tight seams, however it would have worked perfectly with out doing so. I'll be updating that thread this weekend I set axles, links and mocked up the shocks. It might give you a better feel for it. |
05-27-2016, 04:22 PM | #4 |
Pebble Pounder Join Date: May 2014 Location: fernandina beach
I re-built my SCX truggy with the Kodiak frame and everything swapped over pretty well, used the stock skid, accomplished what I wanted to do, which was get a lcg frame and still use my truggy cage and body. You can tell in the pictures what a lcg chassis will do, which is raise the front and rear ends while dropping the center. I ended up with a shorter-looking body, so I may have to get a new body, because you can't "un-trim" a lexan body. The frame is very thick and makes your build super rigid. I also like all the holes for upper link mounts and shock mounts, makes life easy |
05-27-2016, 07:27 PM | #5 |
Newbie Join Date: May 2016 Location: Dartmouth
| Re: Kodiak Metal Works I have had great success with there chassis. I bought the version 1 it gives you great options for your links and driveshaft angles. Also gives you a nice low center of gravity. Here is a couple pictures. Sent from my SAMSUNG-SM-G928A using Tapatalk |
05-27-2016, 10:06 PM | #6 |
Those seem to have more holes than the one i saw. Glad to see some people having good luck with them
05-28-2016, 01:57 AM | #7 |
Yah he just started making a version two. I have the version one. I'm sure if you send him a message you could get either version one or two. Sent from my SAMSUNG-SM-G928A using Tapatalk |
Kodiak Metal Works - Similar Threads | ||||
Ty's Metal Works | TURTLE | Chassis and Suspension | 44 | 12-23-2015 01:07 AM |
