06-07-2016, 11:26 AM | #1 |
Newbie Join Date: Jun 2016 Location: Canada
| Scx10 problems
My rear axle is stiff and difficult to turn any suggestions on how to fix it my run times have also fallen drastically could it be a cause of that it something else
06-07-2016, 11:35 AM | #2 |
Pebble Pounder Join Date: Jun 2013 Location: Espoo, Finland
| Re: Scx10 problems
Most likely (all) bearings has ceased. Open the thing and try to spin the bearings, if they are not 100% smooth, replace with new ones. Sizes can be found in the appropriate PDF manual found at Axial's website. |
06-07-2016, 11:38 AM | #3 |
Rock Crawler Join Date: Aug 2007 Location: Philadelphia
| Re: Scx10 problems +1 Open the axle and see what's going on inside. I've had dumb things like a tiny rock stuck in behind a gear mess things up. Simple fix.
06-07-2016, 12:18 PM | #4 |
| Re: Scx10 problems
Ok I'll get around to tearing open the diff later to see what's going on I haven't opened them up since I bought my scx10
06-07-2016, 01:42 PM | #5 |
Rock Crawler Join Date: Mar 2016 Location: HB
| Re: Scx10 problems
Another easy thing to do is disconnect your driveshaft and spin it from there to make sure it's not a driveline binding issue.
06-07-2016, 02:15 PM | #6 |
| Re: Scx10 problems
Yeah I pulled it off a while back and it was pretty stiff turning inner shaft by hand
06-07-2016, 03:16 PM | #7 |
| Re: Scx10 problems |
06-07-2016, 03:20 PM | #8 |
RCC Addict Join Date: May 2010 Location: So. Charleston. Wv
| Re: Scx10 problems
If you find its the bearings, might as well an get the Fast Eddy bearing kit and replace the front and rear bearing sets
06-07-2016, 04:51 PM | #9 |
| Re: Scx10 problems
So what exactly would I be looking for on the bearing if they're shot
06-07-2016, 06:00 PM | #10 |
| Re: Scx10 problems
They won't spin smoothly. Might be in pieces. Should be pretty easy to tell
06-07-2016, 06:22 PM | #11 |
Rock Crawler Join Date: Jan 2007 Location: Lehigh Valley
06-07-2016, 07:04 PM | #12 |
| Re: Scx10 problems
So I opened up the rear diff pulled out the big gear and inspected it,the bearings,and the housing for debris. It was all good.put the assembly back together and now it some how spins freely with the only difficulty being the weight of the gear.so the the only part left to inspect is the front diff because the transfer case was good and the rear diff assembly. Then I guess put it back together and run it and see if my run time improves before this it started at about 1-1.5 hours down to like 5-15 minutes.so hopefully it goes back to that
06-09-2016, 08:48 PM | #13 |
| Re: Scx10 problems
So i got to run it tonight my run time is up to 30 minutes on a 5000 mah NiMh still shooting for an hour 3rd year owning this since new any suggestions on anything else to assume as a problem. Front diff drag? Or possibly junk electronics?
06-10-2016, 10:06 AM | #14 |
Rock Crawler Join Date: Mar 2006 Location: Dogpatch
| Re: Scx10 problems
Do both front and rear diffs spin freely? What about the center transmission? Drive shafts binding?
06-10-2016, 12:02 PM | #15 |
| Re: Scx10 problems
The transmission is good the rear axle is good just need to check the front axle
06-10-2016, 08:53 PM | #16 |
Rock Crawler Join Date: May 2013 Location: Uniontown
| Re: Scx10 problems
Did you put new grease in there while you had the axle apart? It does eventually break down, even if you never take the thing off road and get dirt and water in there. Sent from my XT1585 using Tapatalk |
06-10-2016, 10:53 PM | #17 |
| Re: Scx10 problems
No i didnt but i have a tube of grease on the work bench but the back axle spun freely enough to be acceptable
06-11-2016, 04:00 PM | #18 |
| Re: Scx10 problems
Front Axle is fine too could be the transfer case or the batteries and electronics arent what they used to be
06-12-2016, 09:42 PM | #19 |
| Re: Scx10 problems
Everything worked great until I accidentally rolled it of a 20 so foot drop destroyed the steering servo and bent one or both VP vvd's on the front
Scx10 problems - Similar Threads | ||||
Scx10 Problems | Trentenowns | Axial SCX-10 | 11 | 07-27-2013 04:26 PM |
help scx10 problems | jaredcrawler185 | Axial SCX-10 | 20 | 04-24-2013 10:23 PM |
scx10 Problems | djbeck88 | Axial SCX-10 | 30 | 03-25-2013 03:52 PM |
scx10 problems | Bronco2x84 | Axial SCX-10 | 3 | 01-10-2013 05:22 PM |
scx10 problems???? | dunwoody | Axial SCX-10 | 1 | 05-18-2011 05:44 PM |
