Thread: 2.2 wheels rubbing on axle when steering hard,
Old 09-20-2016, 04:38 PM   #1
Default 2.2 wheels rubbing on axle when steering hard,
Will the the vanquish 475 hubs work on any wheels? Or are there ones that will? I run 2.2 hot racing wheels I see gpm has a set but I'm not sure on the quality
DTA510 is offline   Reply With Quote
Old 09-20-2016, 05:03 PM   #2
Default Re: 2.2 wheels rubbing on axle when steering hard,
Most manufacturers (LURC, Crawler Innovations, SSD) will specifically note whether their wheels are SLW compatible. If not, it isnt likely. Do the HR wheels have removable hubs?
DeviledEggs is offline   Reply With Quote
Old 10-22-2016, 11:49 PM   #3
Yes they are removable
Old 10-22-2016, 11:54 PM   #4
Moderator
badhoopty's Avatar
depending on what hexes you are running you maybe can get a little more width with a wider hex.
badhoopty is offline   Reply With Quote
2.2 wheels rubbing on axle when steering hard, - Similar Threads
RTR scx10 steering rubbing issue? fatsachs Newbie General 6 12-27-2013 12:31 PM
Steering links rubbing HELP! boots Newbie General 5 08-17-2012 12:34 PM
LF Tire rubbing steering Servo dadgummit Losi Mini-Rock Crawler 17 06-29-2011 12:07 PM
steering link arm rubbing b_atman Axial XR10 9 04-27-2011 09:55 PM
