11-16-2016, 07:15 AM | #1 |
Quarry Creeper Join Date: Aug 2015 Location: Grover, NC
| How tight/loose do you guys set your gear mesh?
How tight/loose do you guys set your gear mesh? And also I run all metal gears in my tranny, what's your opinion on running a hardened steel spur gear? (Stock gearing, just hardened steel, scx10 jeep rubicon rtr). Running a Holmes CrawlMaster 540 brushed motor if that makes any difference...
11-16-2016, 08:03 AM | #2 |
Quarry Creeper Join Date: Jun 2015 Location: Petaluma, Ca
| Re: How tight/loose do you guys set your gear mesh?
I use the piece of paper method when setting my gear mesh. Slide a small piece of paper between the pinion and the spur gear, press together and tighten. Then turn the gears to get paper out works every time.
11-16-2016, 08:33 AM | #3 |
RCC Addict Join Date: Jan 2016 Location: Kelowna, BC
I do the same, but I use the thickest paper I can find, or sometimes even a thing business card.
11-16-2016, 08:37 AM | #4 |
I wanna be Dave Join Date: Dec 2006 Location: here
When I first started in rc's regular notebook paper folded in half. Placing between pinion and spur, then tightening motor.... now I set it by feel/eye.
11-16-2016, 08:55 AM | #5 |
Quarry Creeper Join Date: Jun 2014 Location: Grand Haven, MI
| Re: How tight/loose do you guys set your gear mesh? |
11-16-2016, 12:12 PM | #6 |
11-16-2016, 01:41 PM | #7 |
RCC Addict Join Date: Nov 2014 Location: Nowhere
It takes some practice, but I always set it by eye so that the mesh is as close as possible while still being able to freely wiggle the spur between the pinion teeth. The only truck I can think of where I can hardly see the mesh is the Traxxas 4x4 models, but even then I can still reliably set it via feel. I used the paper a couple times starting out but never really liked it, it's just all based on your preference though.
11-16-2016, 01:48 PM | #8 |
How much wiggle room is adequate? As long as it wiggles slightly at the tightest mesh point is good enough or is it good to back it off a little more than that? Right now I run plastic spur, but I may switch to hardened steel in the near future |
11-16-2016, 01:58 PM | #9 |
It sounds right, and feels right..... just a hint of side play in the teeth, plastic must be a bit tighter due to wear Put the paper in, feel your mesh...... Hang up and Drive |
11-16-2016, 02:15 PM | #10 | |
| Re: How tight/loose do you guys set your gear mesh? Quote:
Here's a video I found that finally details this perfectly: | |
How tight/loose do you guys set your gear mesh? - Similar Threads | ||||
Shimming Diff Tight or Loose? | norco kid | Axial Yeti XL | 13 | 06-12-2016 03:03 PM |
Pinion gear and ring gear mesh question | flyboy320 | Axial Wraith | 18 | 01-09-2016 02:41 PM |
AX30401 HD Over Drive Gear Set MESH too tight? | joe.bielski | Axial SCX-10 | 9 | 08-05-2015 07:21 PM |
Losi CC 12t pinion cant get tight enought mesh! NEED HELP! | Lowlife_Louie | Newbie General | 8 | 07-12-2013 02:52 PM |
Bad Mesh on bevel gear and diff gear out of the box? | Elliott000 | Axial SCX-10 | 3 | 08-19-2011 06:37 PM |
