03-24-2017, 06:38 PM | #1 |
Quarry Creeper Join Date: May 2009 Location: Scotland, UK
| Low Gearing Questions For SCX10. 32p & 48p
Hi all, Had a query regarding low gearing on the SCX10 trans. What's the lowest gearing possible to fit on the standard trans? Just now i'm running 90t spur which looks the biggest, as any bigger will foul the drive shaft. I've a 13t pinion as can't find any smaller than 13t on 48p with the correct bore. Is a larger spur / smaller pinion possible? Also, for the 32p gearing. What's the smallest pinion you can use with the standard spur, and what's the largest spur that can be fitted with the larger 32p gears? Thank you. |
03-26-2017, 01:16 PM | #2 |
Pebble Pounder Join Date: Dec 2015 Location: Portugal
| Re: Low Gearing Questions For SCX10. 32p & 48p
Just bought 9, 10, 11 and 12T 32p from GoolRc and RW. Took some time to find them. Biggest spur in 32p I would estimate to be 62T as the 64T will foul the rear drive shafts when suspension is compressed. Sent from my SM-G900F using Tapatalk |
Low Gearing Questions For SCX10. 32p & 48p - Similar Threads | ||||
What gearing should I choose 48p to 32p | Tom95YJ | Axial SCX-10 | 10 | 01-17-2014 12:07 AM |
Spur pinion Shootout 32p VS. 48p SCX10 | Willy Smellson | Axial SCX-10 | 6 | 03-09-2013 03:12 PM |
