04-28-2017, 02:30 AM | #1 |
Newbie Join Date: Apr 2017 Location: Brisbane
| Spur Gear stripped
Hey guys. Today I adjusted my spur Gear as per the instructions. When I bought the truck it was tightened fully so I back it off 1.5 turns. Then I took my truck out and I heard the slipper slip and then my spur was stripped. Should I be running it full tight or as per the manual? Forgot to mention my truck is a g6 falken edition. Pretty much stock except for axial metal 4 link front and rear, metal steering links and battery moved to the front. |
04-28-2017, 02:38 AM | #2 |
I wanna be Dave Join Date: Nov 2014 Location: West Texas
| Re: Spur Gear stripped
Try a Nitro evader duratrax spur gear 32p 56t very tough 149 r/c worx /scalerfab Team Driver |
04-28-2017, 03:07 AM | #3 |
So I'll need to grab a 32 pitch Pinion to? Do they make those spurs closer to 80t. Pretty happy with the speed I've got at the moment |
04-28-2017, 05:54 AM | #4 |
Pebble Pounder Join Date: Feb 2017 Location: US
I wouldn't go much larger than a 60 tooth. Go down to a 13 tooth or 12 tooth pinion if you want a bit slower.. Yes you could get these in 32 or stuck with the 48 pitch. 32 is a bit louder but much stronger Sent from my LG-H830 using Tapatalk |
04-28-2017, 10:39 AM | #5 | |
Rock Stacker Join Date: Oct 2016 Location: Estonia
| Re: Spur Gear stripped Quote:
04-28-2017, 01:09 PM | #6 |
Pebble Pounder Join Date: Feb 2015 Location: Kansas city
Sounds like the mesh may have been a little loose. Sent from my 2PS64 using Tapatalk |
04-28-2017, 05:27 PM | #7 |
Rock Crawler Join Date: Jan 2017 Location: DownUnner
Adjusting the slipper so it slips means it protects the spur and internal gearbox gears. It's false economy as it's more expensive to replace anyway. The only way to strip the spur with the stock setup is to have it too lose. Adjust correctly as even with a big motor on 3S treated like total crap they don't strip. |
05-01-2017, 06:47 AM | #8 |
Rock Crawler Join Date: May 2013 Location: Uniontown
That sounds like a motor adjustment issue unless there was something wrong with the spur bearing and the slipper was taking up the slack. Sent from my XT1585 using Tapatalk |
Spur Gear stripped - Similar Threads | ||||
Which pinion gear works best with RC4WD Steel spur gear? | e32lover | HPI Wheely King | 8 | 03-10-2013 06:09 PM |
Which spur gear and pinion gear with 35t motor | vegas1973 | General Crawlers | 1 | 08-19-2012 11:42 AM |
stripped spur | Drvnbeing | Team Losi Comp Crawler | 4 | 05-17-2010 10:55 PM |
Stripped out tranny gear and Spur, Metal ? | toy4crawlin | Axial AX-10 Scorpion | 3 | 08-17-2009 03:53 PM |
Wobbling spur gear....Need alum. gear hub! | sickfab | HPI Wheely King | 26 | 10-01-2007 02:09 AM |
