06-22-2017, 04:25 PM | #1 |
Rock Stacker Join Date: Jul 2014 Location: Hollis
| Another opinion needed....
Hi all, I'm looking into my next round of upgrades for the Deadbolt. One I'm looking at is an 8 deg. setup, mainly the Pro from SSD. My question is; is this really needed for a trail truck, or is this more of a luxury. Thanks for the input Scott Last edited by T4rscott; 06-22-2017 at 06:35 PM. Reason: Spelling/ brain fart |
06-23-2017, 01:37 PM | #2 |
Rock Crawler Join Date: Dec 2016 Location: Minnesota
| Re: Another opinion needed....
I have the SSD kit on my Deadbolt and love it! Definitely an improvement on the trail but make sure you get a set of universals to take advantage of the steering angle vs the stock dogbones. Sent from my SM-G930V using Tapatalk |
06-23-2017, 01:38 PM | #3 |
Rock Stacker Join Date: Jan 2017 Location: Kennesaw
I guess my question would be do you compete? If you're like me and just tootle around and have fun doing that then I don't see the value in the investment (Other then it looks really wicked). If you compete, well than it's probably more important to you. I'm interested in seeing if you notice any real difference if you decide to do it. I too have a Deadbolt that I'm always trying to find something to upgrade! |
06-23-2017, 01:39 PM | #4 | |
| Re: Another opinion needed.... Quote:
I'm not even sure what the exact benefit is! EDIT: Nevermind! I just did some reading on Zero Ackerman and now I understand. Changing my answer to "If you can afford it, go for it". This will be one of those "Later when I have the money" sort of upgrades for me. Last edited by Loosenuts; 06-23-2017 at 01:45 PM. | |
06-23-2017, 01:47 PM | #5 |
Well more steering angle is always an improvement. Allows you to make tighter turns around trees, rocks or other objects. There is no disadvantage IMO to achieving the most steering angle as possible. You can always adjust endpoints on your servo if you feel it's too much angle. My LHS has a trail and I noticed I could get through spots in one go vs having to back up and adjust my angles to make it around and between trees. Sent from my SM-G930V using Tapatalk |
06-23-2017, 02:18 PM | #6 | |
RCC Addict Join Date: May 2015 Location: Price Twp.
You will get more angle for less money. On a trail truck it is more then enough. If you don't want to do that you can spend $12.00 on Chinese cvd's, and 40 on VP clone chubs and knuckles. For $52.00 your there... Now more importantly have you changed gears in the front dif? You will crawl better and get a much better turning radius with the overdrive front. | |
06-23-2017, 04:13 PM | #7 |
Thanks everyone for the info. I think I'm definitely going to put some weight in the axles first. I'm going to buy a set of OTVDs and stuff them in. I did do a little light grinding and put grub screws in the front. So after the OTVDS go in, I'll re-evaluate. Where's the best place to find the VP clone chubs and knuckles? |
Another opinion needed.... - Similar Threads | ||||
Your opinion needed! | Duuuuuuuude | 1.5 Scale Rigs | 24 | 02-25-2015 11:52 AM |
Opinion needed | kincer | Chit Chat | 7 | 05-14-2013 05:45 AM |
EZ run? Opinion needed! | jado6006 | Electronics | 5 | 05-28-2012 06:12 PM |
wheel opinion needed | rchippie | General Crawlers | 6 | 03-18-2009 10:44 AM |
1:1 tire opinion needed | wheelspinner | 1:1 Full Size Vehicles | 37 | 04-06-2007 01:20 PM |
