08-12-2017, 05:34 AM | #1 |
Newbie Join Date: Apr 2017 Location: Brisbane
| sanwa mt4s setup for scx10
Hey guys, posted in the electronics section a few days ago and got no answers, so ill try here. Ive got my winch setup on the lever, which works great. Except i sometimes bump the lever which is obviously bad( winding it in to far/dropping it on the ground and tangling in axles) Ive read in a few places that you can use one of the other assignable buttons to enable and disable the lever. Would anyone know how to do this? Cheers! |
08-15-2017, 09:53 AM | #2 |
Rock Stacker Join Date: Jan 2017 Location: Kennesaw
| Re: sanwa mt4s setup for scx10
Forgive us Americans but when you say you have it setup on a lever that means something else to us. So what I think you mean may not be what you mean. I had my winch originally setup to be operated manually with a switch on the truck. Flip it forward to let out, middle to stop, back to reel in. I have since added a winch controller that is operated by my 3rd channel on my radio. I myself noticed that I was always bumping the 3rd channel buttons with my fingers while I was running my truck allowing the winch to spool out or in. So I put a manually operated switch in to turn off the power to the winch so that I could make sure the radio was set properly before engaging the winch. But this sounds like the reverse of what you are asking. |
08-15-2017, 01:15 PM | #3 |
I frequently use my M12 for controlling my scale trucks which has the same lever setup. Never tried setting one of the switches to enable/disable the lever but I would imagine that you would have to assign the lever to whatever Aux channel you use for the winch and assign a button or switch to the same channel with 2 position movement and endpoints at 0 and 100. I have no idea if that will work but that is the only theoretical way I can see how to set it up, the manual doesn't actually say this is a possible setting.
08-15-2017, 06:57 PM | #4 | |
| Re: sanwa mt4s setup for scx10 Quote:
its setup on the lever on the transmitter. | |
08-15-2017, 06:59 PM | #5 | |
will report back with my results. Cheers! | |
08-12-2019, 02:39 PM | #6 |
Newbie Join Date: Jul 2019 Location: Canada
Not wanting to resurrect an old thread but I was wondering if I could trouble someone for a "how-to" on how to setup a Sanwa M12 with RX-452 (will upgrade if this works) to control the RC4WD Warn winch with the RC4WD controller for use from the radio. I have looked and it seems like I am still missing something. I can't get it to work with the lever. I would like to have it where I use a switch to enable/disable the lever and use the lever to control in and out of the winch. I am still searching the forums here and google but hope that someone can help me out as I have yet to find a proper way to make this work. Jon |
sanwa mt4s setup for scx10 - Similar Threads | ||||
mt4s setup | nicos | Electronics | 5 | 01-04-2017 06:24 PM |
sanwa/airtronics mt4s backlight | nicos | Electronics | 1 | 12-03-2016 10:33 AM |
Binding issue Sanwa MT4S and Yeti XL | o0ben0o | Electronics | 3 | 11-23-2014 07:50 PM |
