10-17-2017, 08:53 PM | #1 |
Newbie Join Date: Aug 2015 Location: bowling green
| ar44 swap
What all is needed to put the ar44s on an scx10 other than the axles themselves. Also, do they sell these axles as a complete set anywhere?
10-18-2017, 11:26 AM | #2 |
Rock Stacker Join Date: Sep 2016 Location: United States
| Re: ar44 swap
Since you can't mount the servo to the axle you will need some kind of CMS kit. Pricewise it would probably be about the same as aftermarket to just get the bits from the SCX10ii, and it would be a lot less complicated. Not sure on links, but they should work out close enough that you can just adjust with some shims between the rod and the rod end.
10-18-2017, 02:14 PM | #3 |
| Re: ar44 swap
Tower hobbies lists the AR44 axles for $68 each, expected in mid Novenber.
10-18-2017, 02:17 PM | #4 |
| Re: ar44 swap |
10-18-2017, 02:33 PM | #5 |
RCC Addict Join Date: Oct 2014 Location: UK
| Re: ar44 swap
Axles plus this: Pro44 CMS & Titanium Link Set / V2 Conversion for SCX10 |
10-18-2017, 03:50 PM | #6 |
| Re: ar44 swap What? No way the plastic axles housings are $70. These are the axle housings: Axial AR44 Axle Housing: AX31401 - 10.99 https://www.towerhobbies.com/cgi-bin...?&I=LXFZWV&P=7 These are what I'm referring to: Axial AR44 Locked Axle Set Front/Rear Complete: AX31438 -67.99 Axial AR44 Locked Axle Set Front/Rear Complete | TowerHobbies.com I'm not sure why it's marked front/rear or what exactly comes with it yet, but I'm pretty sure it's not just a housing. The "Axle... Complete" part of it suggests otherwise. Last edited by OSRC; 10-18-2017 at 03:53 PM. |
10-18-2017, 04:40 PM | #7 |
| Re: ar44 swap
The complete just means it has the diff cover, link mounts, etc... The front/rear means it works for either if you get the knuckles or lockouts, i went thru this when they first came out
10-18-2017, 05:10 PM | #8 |
| Re: ar44 swap
You have to be kidding me (I can't even find this part number on Axial's site)- why call it a complete axle then??
10-18-2017, 05:20 PM | #9 |
| Re: ar44 swap
I said the exact same thing when they did this originally... I didnt beleive it..but time will tell if they sell it complete this time
10-18-2017, 05:28 PM | #10 |
Quarry Creeper Join Date: Oct 2011 Location: Land of earthquakes
| Re: ar44 swap You can with a UC-FAB servo mount for the AR44 https://www.facebook.com/UltraCustom...718814/?type=3 |
10-18-2017, 05:34 PM | #11 |
| Re: ar44 swap
Well, I cancelled my order.... Thanks for the clarification. I'll wait and see what exactly they come with.
10-18-2017, 08:46 PM | #12 | |
| Re: ar44 swap Quote:
10-19-2017, 05:30 AM | #13 |
| Re: ar44 swap
Excellent guys i really appreciate it
10-19-2017, 06:59 AM | #14 |
| Re: ar44 swap
$68 for an incomplete, plastic axle is nucking futs!
