10-20-2017, 11:12 AM | #1 |
Newbie Join Date: Jun 2015 Location: South Korea
| What am I missing???
Here’s what I have. I installed some D60 axles and Vanguish Stage 1 goodies on them. But as you can see once I put the wheels on... no clearance. I tried putting on some traxxas hub but still doesn’t work. I am sure that this has been covered somewhere before but I cannot find it. Thanks for the help |
10-20-2017, 11:25 AM | #2 |
Newbie Join Date: Oct 2014 Location: Mobile
| Re: What am I missing???
I don't have any personal experience with those parts, but as I see it you have 4 options: 1: replace the spindles with ones with angled control arms 2: use skinnier tires 3: Depending on if you have any length to spare on your stub axle, use wider wheel hexes to space the rim out some 4: find wheels with larger back spacing. Looks like that particular combination of parts wasn't meant to work together. Hope this helps! Sent from my iPhone using Tapatalk |
10-20-2017, 11:25 AM | #3 |
RCC Addict Join Date: Oct 2014 Location: UK
Ok so you should have got the SSD Pro Steering kit instead and you wouldn't have this problem. You need to get some offset hubs to move the wheels out a little. Last edited by SSD; 10-20-2017 at 01:35 PM. |
10-20-2017, 11:26 AM | #4 |
RCC Addict Join Date: Apr 2009 Location: LA
What's the thickness of your 12mm wheel hexes? You may need thicker ones to tune your current wheel and tire setup.
10-20-2017, 11:34 AM | #5 |
The vanquish setup is designed to be used slw hubs. An adjustable width hub set sold by Vanquish. Many rims are Slw compatable and all are 6 lug.
10-20-2017, 11:50 AM | #6 |
| Re: What am I missing??? |
10-20-2017, 11:51 AM | #7 |
10-20-2017, 11:52 AM | #8 |
10-20-2017, 11:55 AM | #9 |
This is why I hate and despise the VP 8* setup....it forces you to buy slw wheels or jump thru a bunch of hoops buying spacers and different wheels to get the damn things to work on your truck....the axial high clearance knuckles and adjustable c-hubs dont. They plain work with the wheels you already have and they give a nice reduction in turning radius. I just replaced the vp crap on mine and will sell them in the classifieds.
10-20-2017, 01:21 PM | #10 |
I joined the Band! Join Date: Mar 2009 Location: Right Here
10-20-2017, 01:27 PM | #11 |
I’m in the process of installing the stage 1 kit myself and now I’m regretting it....I’m already having trouble fitting my CVD’s. I’ll look when I get home, but it looks like one might be able to drill new holes in the arm closer to the knuckle and cut off the excess. Sent from my iPhone using Tapatalk |
10-20-2017, 01:37 PM | #12 |
10-20-2017, 02:45 PM | #13 |
10-20-2017, 02:55 PM | #14 |
The slw hubs are fine as long as you are running slw compatible wheels...if not, you have limited options
Last edited by allanon1965; 10-20-2017 at 03:31 PM. Reason: what the hell are hibs? |
10-20-2017, 04:35 PM | #15 | |
| Re: What am I missing??? Quote:
Sooo I have SSD wheels...how do I know if they are SLW compatible. And can some one please tell me what slw even means..lol Sent from my iPad using Tapatalk | |
10-20-2017, 04:45 PM | #16 | |
I feel ya. If I did t have so much money wrapped into it, I would start from scratch..lol meaning new rig..lol Sent from my iPad using Tapatalk | |
10-20-2017, 05:46 PM | #17 | |
SLW hubs are made by Vanquish Products(VP) Go to the SSD website and see what hubs they recommend . Yes they will fit, but you need the proper width Hang up and Drive Last edited by mikemcE; 10-20-2017 at 05:48 PM. | |
10-21-2017, 03:56 AM | #18 | |
We have 3mm offset rotor hubs but I'm not sure it's enough just by looking at your photos. | |
10-21-2017, 07:52 AM | #19 |
Rock Stacker Join Date: Jan 2014 Location: Cedar Falls
What I see in the picture's, He needs to start with 425...I would go with https://www.amainhobbies.com/vanquis...s01043/p177786 that tire is tight.
10-24-2017, 11:16 AM | #20 |
RCC Addict Join Date: Jun 2006 Location: Durham, NC, USA
What am I missing??? - Similar Threads | ||||
Am I missing something? | scale4x4 | Chit Chat | 12 | 05-30-2014 03:11 PM |
Am I missing something? | rik | Chit Chat | 5 | 08-16-2011 06:13 AM |
what am I missing? | Nylintbucket | Axial AX-10 Scorpion | 11 | 11-06-2009 09:05 PM |
What am I missing? | Devilbrad | Newbie General | 9 | 07-29-2009 01:23 PM |
