02-07-2018, 06:21 PM | #1 |
Quarry Creeper Join Date: Jan 2009 Location: WA state
| Dead RAM build
Figured I'd start a build thread for this 1:6 scale New Bright Dodge Ram based off my Axial deadbolt. Should be an interesting thread when all is said and done. The most important part I want to note is that I WILL NOT be making a custom frame. I'll be using links and longer shocks (AX10 Scorpion) to get the wheel base right. It should be a good thread or anyone who wants a bigger RC without having to make a frame and all that noise. Axles - Front 200k oil/Rear 500k oil/Team Associated oil Front - SSD RC aluminum diamond axle ordered https://www.amainhobbies.com/ssd-rc-...d00112/p505921 Rear - stock axle with underdrive (AX30402), will be ordering SSD RC aluminum diamond Axle https://www.amainhobbies.com/ssd-rc-...d00069/p498752 Trans - stock with Vader products monkey skid which moves the engine forward. May have to return to stock skid to help with wheelbase. Steering - SSD CMS ordered - will probably need some modification to work with the 14.5in wheelbase https://www.amainhobbies.com/ssd-rc-...d00026/p498712 Suspension - All aluminum links. will be using 106mm along with smaller threaded and non-thread link spacers to get the wheel base correct. Shocks - Stock AX10 Scorpion with softer springs rear and stiffer front if I remember correctly. I think they are 100mm shocks. Wheel and tires - 2.2 RC4WD ROKLOX (5.55x1.69) with axial beadlocks which will be replaced with these brodozer wheels Body - 1:6 scale New Bright Dodge Ram "Mud Slinger" Bumpers - Need a front winch bumper, sliders and wheel wells, rear will stay stock. Motor is a 35t for now. Might go brushless towards the end of the build. Pictures of it as a deadbolt for memories... Let me know what you guys think. Tips and pointers are greatly appreciated! |
03-07-2018, 10:16 AM | #2 |
| Re: Dead RAM build
Finally got it together and running. 15 inch wheel base on Wraith Axles. Rear stock AX10 shocks, front 118mm Integy Alum shocks. Looks pretty janky under the body, but everything works great haha Had a problem with the front drive shaft rubbing on the upper link, but I had some bent links laying around so I threw those on. Rear suspension Front suspension I got the stock Deadbolt sliders to work, just needed to buy these metal things to extend them out. I'm sure there is a better option out there, just haven't looked that hard. Mounted the rear with the stock body mounts. The tool box in the bed hides the clips Mounted the front with the stock new bright body mounts using a gaggle of parts haha works well though Front with RC4WD 12mm wheel widners. Look good and works as they should, but I didn't want to use widners. Front with AR60s Rear with AR60s First test run with a 35t. Thinking of going brushless, but I'm not 100% yet Taking out the trash haha Last edited by xtreme4x2; 03-07-2018 at 03:21 PM. |
03-25-2018, 07:22 PM | #3 |
Newbie Join Date: Nov 2017 Location: San Luis Obispo
| Re: Dead RAM build
Looking good man!! Just got my AR60's on! We did some similar things to make it work haha. I went with 14.5" wheelbase for now. May tweak later. & What size TSL's did you go with? Love the taking out the trash pic btw haha. Sent from my SAMSUNG-SM-G930A using Tapatalk |
03-25-2018, 07:34 PM | #4 | |
| Re: Dead RAM build Quote:
Tags |
1/6, axial deadbolt, dodge, ssd-rc |
Dead RAM build - Similar Threads | ||||
Ram Build/ Photo Dump | DubVDUBBIN | Axial SCX-10 | 23 | 05-01-2017 06:49 PM |
Ram 2500 scx10 build | Dad,Canyoufix? | Axial SCX-10 | 81 | 12-14-2015 01:30 PM |
SAL45 Dodge Ram Build | SAL45 | Axial SCX-10 | 20 | 05-13-2015 07:50 AM |
My Dodge Ram Build. | HahnsB2 | Axial SCX-10 | 17 | 06-06-2011 07:14 PM |
Dodge Ram Build - First Attempt | CrawlerGraphics | 1.9 Scale Rigs | 77 | 04-06-2008 09:39 PM |
