![]() | #1 |
Rock Stacker Join Date: Aug 2014 Location: NYC
Hey guys im looking to upgrade my daughter's scx10. Looking to update it with a brush-less system. Looking for a recommendations for a setup. Also my servo is still mounted on the axle would it make much difference if i went a CMS Started out a Scx10 JK kit Holmes Hobbies Torque master Expert 27t TorqueMaster BR-XL Trailmaster bls Hv-400 servo Traxxas Big Bore Shocks Pitbull Rock Beast Tires MIP Drive Shafts Metal Trans Gears ![]() |
![]() | #2 |
Recommending a brushless system really depends on what you are looking for out of the new system and how much you want to spend. Generally, you can't go wrong with the Castle Mamba X for the ESC (waterproof, strong built in BEC, has all the adjustments needed for a crawler) . The Mamba Micro X is good for lighter trucks with lower KV motors (540 sized 2200ishkv motors) if you run an external BEC. There are lots of cheap brushless ESCs on the market but they generally lack the adjustments or low end resolution that a crawler would want. If you are limited on budget, I would get a good ESC and save some money on a lesser motor. As for motors, I pretty much run either Holmes or Tekin motors as they are designed for low speed control and smoothness. Castle's Slate motors are a pretty good value for the money but lack the low end refinement and overall power of the Holmes and Tekin offerings. If you are happy with the wheelspeed of the 27T brushed motor in there now, you will want something around 2200kv. For something different and not too expensive, consider the Holmes 1800kv Revolver with a Castle Sidewinder 4. It is an unsensored setup but feels as smooth as a brushed motor and has a ton of torque. The only down side is the Revolver make some rather unique noises, Holmes has a video of the motor in action so you can hear what I mean. |
![]() | #3 |
Quarry Creeper Join Date: May 2017 Location: Devon
Axle mounted servo works better than CMS. The latter is for those scale points really ![]() Any particular reason to look at brushless? HW1080 is a great ESC and will save you a ton of cash. Has a good internal BEC and waterproof... Sent from my Pixel using Tapatalk |
![]() | #4 | |
| ![]() Quote:
HR Shock Rebuild Questions | Robudda | Axial Wraith | 0 | 08-12-2016 06:44 PM |
Motor rebuild questions | Bansh88 | Axial XR10 | 13 | 02-21-2014 10:09 AM |
08's rebuild (pics n questions) | 08sv | Axial SCX-10 | 28 | 12-21-2012 04:46 AM |
Super 300 rebuild questions | Harvo | EnRoute Berg | 16 | 06-27-2012 03:28 PM |
dumb rebuild shock questions | bcmaxx | Axial AX-10 Scorpion | 9 | 08-28-2009 07:30 PM |
