12-31-2018, 11:30 AM | #1 |
Newbie Join Date: Apr 2009 Location: deltona
| motor and gearing
I was just recently given a used jeep recon g6 falken tire edition SCX10. it currently has a 55t motor in it and that is just to slow for me. what is a good size motor turn and pinion and spur heat size to run in this truck? I will mostly just be doing some basic trail riding and running around in the yard here in florida.i dont want this to be a fast race truck but still want it to be fast enough to be fun playing in the yard and open fields or maybe a trail ride or something. so any help on what turn motor to run and what size pinion and spur to run will be awesome. thanks everyone in advance for the help.
12-31-2018, 02:35 PM | #2 |
Quarry Creeper Join Date: May 2017 Location: Devon
| Re: motor and gearing
55t is a tad slow but can be worked with by swapping pinion and spur gears. Ideally around 5:1 ratio pinion to spur but if no good get that gap smaller or try a 27t or 35t motor Sent from my Pixel using Tapatalk |
12-31-2018, 08:51 PM | #3 | |
| Re: motor and gearing Quote:
I was thinking about going to a 27t motor what would be the ideal pi in and spur tooth size for a 27t motor? | |
12-31-2018, 11:26 PM | #4 |
Depends on tire size.... I run stock 13/56 gearing with 4.75' tires on my wife's scx10 on 3s lipos and a 35t motor. She finds it fast enough to climb looses sandy hills but not uncontrolled. Plenty of low speed resolution.... The esc has a lot to do with the bottom end resolution. |
01-01-2019, 08:46 AM | #5 | |
I find a motor fast enough to get to 6-8mph when geared 40-60:1 on 3S is good for all situations. Pretty much all my scale trucks, regardless of brand, fall somewhere around that range. | |
01-01-2019, 10:46 AM | #6 | |
01-01-2019, 10:55 AM | #7 | |
Sent from my Pixel using Tapatalk | |
01-01-2019, 11:08 AM | #8 |
| Re: motor and gearing |
01-01-2019, 11:13 AM | #9 |
Ah! Find that out then grab some pinion choices as they're a cheap option to tailor what you want. Sent from my Pixel using Tapatalk |
01-01-2019, 11:26 AM | #10 |
With that big of a tire I would be running 60:1 A gearing chart for smaller tires... https://goo.gl/images/tggxKx Gear ratio calculations and formula... Last edited by lonleycreeper; 01-01-2019 at 11:37 AM. |
01-01-2019, 02:32 PM | #11 |
01-01-2019, 04:36 PM | #12 |
01-01-2019, 05:04 PM | #13 |
I personally would start with an 10t pinion and go from there. It's only 42:1 so you might be making your motor hot and reducing run time by turning amps into heat getting those big tires rolling.
01-02-2019, 12:11 AM | #14 |
01-03-2019, 10:38 AM | #15 |
01-03-2019, 11:17 AM | #16 |
01-03-2019, 06:38 PM | #17 |
motor and gearing - Similar Threads | ||||
High Turn Motor & Long Gearing vs Low Turn Motor & Short Gearing. | Hardcoretam | Electronics | 11 | 03-15-2017 11:23 PM |
Gearing vs motor | 123nanez | Axial Wraith | 12 | 02-12-2015 12:01 PM |
CC-01 motor and gearing | Vicious-peanut | Tamiya XC/CC01 | 4 | 07-24-2013 06:43 AM |
Motor and gearing... | silversweater | Electronics | 3 | 02-24-2013 09:47 PM |
20t motor and 45t motor gearing question? | rcstrike | Newbie General | 1 | 11-16-2011 03:40 PM |
