03-23-2019, 11:31 AM | #1 |
Rock Stacker Join Date: Jan 2012 Location: North Delta
| Need a good transmission output gear.
Velion powered SCX10, already have hardened gears through the whole truck, issue I have is the final output gear in the transmission has the flats ground in it for the drive shafts, these shake loose every 5 min of driving, I need to find a brand of output gears that can handle the power but have the drilled holes in it to fasten the driveshafts to. I have drilled ones in the axles and no issues on those ends. Needs to be strong, the rig has large grippy tires and often running on 3s lipo, worked hard. |
03-23-2019, 11:48 AM | #2 |
| Re: Need a good transmission output gear.
Super shafty is your friend... https://supershafty.com/collections/transmissions I run the old RRP one piece without the holes as well. I use a 4mm grub screw and do not have the issues I do with the 3mm. I also double grub the the 3mm and don't have issues as long as I use blue locktite. 3000 kv 4 pole on 3s powering a heavy hard bodied 2.2 truck. |
03-23-2019, 12:03 PM | #3 |
Thanks for the tip, so then this one should be all I need or am I better to buy the separate output shafts? https://supershafty.com/collections/...-main-gear-5mm |
03-23-2019, 02:43 PM | #4 |
Yes that should do it.
10-10-2019, 02:01 AM | #5 |
RCC Addict Join Date: Jun 2006 Location: Durham, NC, USA
can this part be bought elsewhere? SS is showing 'out of stock'
10-12-2019, 12:10 PM | #6 |
Check Amain and Rpp
10-13-2019, 09:11 AM | #7 |
i have the hot racing and ssd shafts the hr is almost 5 years old and showing slight ware at the pin hole the ssd is about 2 years old and im not seeing any ware but nothing lasts forever i think as long as there hardened steel and not cheesium your good
12-13-2019, 07:33 AM | #8 |
RCC Addict Join Date: Aug 2014 Location: Virginia, Near DC, USA
Get yourself a spray can of CRC Electronics Cleaner and a bottle of Red Loc-Tite, use the Electronics Cleaner to degrease the grub screws and the screw-holes in the driveshafts, and use the Red Loc-Tite to secure the grub screws. Allow the Red Loc-Tite to harden overnight before use. If you ever need to take it apart again and you can't get the grub screws to come loose, a couple seconds of heat from a cigarette lighter will melt the Loc-Tite enough to allow you to loosen the grub screws.
12-13-2019, 11:00 AM | #9 | ||
| Re: Need a good transmission output gear. Quote:
12-20-2019, 07:02 AM | #10 |
Rock Crawler Join Date: Dec 2008 Location: Fortuna Calif.
Robison racing makes an awesome one piece out put shaft/gear. Bullet proof |
Need a good transmission output gear. - Similar Threads | ||||
transmission output question | JDIRCC | Axial SCX-10 | 8 | 07-13-2014 01:15 PM |
transmission output shaft :( | meanbgreen | Axial SCX-10 | 15 | 11-18-2011 02:41 PM |
Transmission output sheared | lifttec999 | Axial AX-10 Scorpion | 2 | 08-05-2008 09:18 PM |
Rear Transmission output | glondark | Axial AX-10 Scorpion | 1 | 03-23-2008 04:52 PM |
Transmission output shaft | MaXX_CrAWlER7 | Axial AX-10 Scorpion | 3 | 03-23-2008 07:39 AM |
